The PT-9600 allows you to label in more ways than ever, so it's the ideal machine to have by your side is you want to keep everything perfectly ordered and organised.
Whether you use it with your PC or Mac or as a standalone electronic label printer, the PT-9600 delivers sharp, clear results – even when you're dealing with bar codes and serial numbers – and you can include a wide range of common industry symbols on your labels too.
This hardworking machine also lets you download label designs and transfer images and graphics. The notebook-style portability makes it simple to apply crack and peel labels, while the backlit display also makes previewing and editing easy.
No job's too big or too small for the versatile label printer, which produce high quality, durable labels that always stay put.
- Brother P-Touch PT-9600 - labelmaker
- Printer Type
- Labelmaker
- Form Factor
- Portable
- 2.2 kg
- Max Media Size
- Roll (3.6cm)
- Print Speed
- Up to 20 mm/sec
- Max Resolution (B&W)
- 360 dpi
- Cutter
- Interface
- USB, serial
- Flash Memory Installed (Max)
- 8 MB
- Barcodes
- Code 39, UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5
- Media Type
- Laminated tape, fabric tape, security tape, design tape, lettering tape
- Compatible Tapes
- TZ tape
- Fonts
- Brussels, Florida, Helsinki, US, San Diego, Los Angeles, Istanbul, Brunei Bold, Bermuda Script, Letter Gothic
- Character Sizes
- Auto, 9 points, 6 points, 36 points, 24 points, 18 points, 12 points, 10 points, 14 points, 20 points, 28 points, 7 points, 11 points, 5 points, 56 points, 72 points, 48 points, 16 points, 8 points, 76 points, 64 points, 40 points, 4 points, 22 points, 32 points
- Styles & Effects
- Vertical, Mirror, rotated text
- 16 line printing, auto currency calculation
- Display Resolution
- 3 lines x 20 characters
- Keyboard
- QWERTY
- Total Media Capacity
- 1 roll
- Battery
- Nickel Metal Hydride
- System Requirements
- Microsoft Windows 98 Second Edition, Apple MacOS 8.6 or later, Microsoft Windows 98/ME/2000/XP
- Enclosure Colour
- Dark grey
- 1-year warranty
- 23.6 cm x 30.2 cm x 10.4 cm
- Printer Type
- Labelmaker
- Enclosure Colour
- Dark grey
Printer
- Print Speed
- Up to 20 mm/sec
- Built-in Devices
- Character keyboard, status LCD, cutter
- Connectivity Technology
- Wired
- Interface
- USB, serial
- 360 dpi
- Fonts
- Character Sizes
- Styles & Effects
- Auto Cutter
- Keyboard
- QWERTY
- Repeating Printing
- 999 copies
- Barcodes
Flash Memory
- Flash Memory
- 8 MB
Media Handling
- Media Type
- Compatible Tapes
- TZ tape
- Max Media Size
- Roll (3.6cm)
- Media Sizes
- Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (3.6cm)
- 1 roll
- Media Feeders
- 1 x manual - 1 roll - Roll (3.6cm)
- Connections
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB cable
- Power Device
- Power adapter + battery charger
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows 98/2000/ME/XP - RAM 64 MB - HD 20 MB , Windows 98 SE - RAM 64 MB - HD 20 MB , MacOS 8.6 or later - PowerPC RAM 32 MB - HD 20 MB
- Limited warranty - 1 year
- 23.6 cm
- 30.2 cm
- 10.4 cm
- 2.2 kg
