Brother MFC-L9570CDW Colour Laser Multifunction Printer
Quicklinx: CTNYWS00 Mfr#: MFCL9570CDWZU1
Functionality: Copier, Fax, Printer, Scanner
Output Type: Colour
Technology: Laser
Max Print Speed: 31ppm
£760.80 ex VAT
£912.96 inc VAT
MFC-L9570CDW
With an intuitive 17.6cm colour Touchscreen 2-sided scan speeds of 100ipm in colour and a choice of toner cartridges are only some of the highlights of this model.
Key Features
  • Fast print speeds of up to 31ppm colour and mono
  • 2-sided scan speeds of 100ipm colour and mono
  • Paper input of up to 300 sheets
  • Maximum paper input of up to
  • 2380 sheets
  • Automatic 2-Sided Printing
  • Optional high-yield replacement cartridges 9000 black 9000 page cyan magenta and yellow toner cartridges
  • High speed wired (10Base-T/100 Base-TX/1000Base-T) and wireless (IEEE 802.11b/g/n) network interfaces
  • Integrated NFC card reader
  • Intuitive 17.6cm Colour Touchscreen
Increase productivity levels
  • IProductivity is increased significantly thanks to the fast print speeds of up to 31ppm and 2-sided scan speeds of 100ipm in colour and mono.
  • IMaximise your efficiency with built-in wireless IEEE 802.11b/g/n and ethernet 10Base-T/100Base-TX/1000Base-T.
  • IEasily print from your mobile device using Brother’s iPrint&Scan Brother print service plugin for Android Google Cloud Print 2.0 Mopria and AirPrint.
  • IOutstanding paper handling options with a standard paper capacity of up to 300 sheets expandable to 2380 sheets
Meeting security challenges
Modern businesses demand the highest levels of security. With Secure Function Lock 3.0 Active Directory Authentication Internet Protocol Security (IPsec) 802.1x and Secure Print you can be confident that your documents are safe with near field communication (NFC) functionality
Flexible and low running costs
Designed for high volume printing environments the MFC-L9570CDW includes a 6500 page black cyan magenta and yellow toners and can take an optional 9000 page black cyan magenta and yellow page toners to lower your running costs even further
Brother MFC-L9570CDW - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
United Kingdom
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
6000 pages
Max Copying Speed
Up to 31 ppm (mono) / up to 31 ppm (colour)
Max Copying Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 2400 dpi
Display
7"
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
80 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
Standard Media Capacity
300 sheets
Max Media Capacity
2380 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to USB host
AC 230 V (50/60Hz)
49.5 cm x 52.6 cm x 54.9 cm
29.7 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - colour
80000 pages
6000 pages
Display Diagonal Size
7"
Colour Support
Display Features
Touch screen
AirPrint Enabled
United Kingdom
Standard Memory
1 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PDF 1.7, XPS
Automatic Duplexing
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Scanning Resolution Details
1200 x 2400 dpi - flatbed , 1200 x 600 dpi - ADF
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 500 pages
Transmission Memory Capacity
Up to 500 pages
PC Faxing
Fax Machine Features
Speed Dialing
300 station(s)
Broadcast Transmission
350 stations
Automatic redialing, group dialling
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
80 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
300 sheets
Max Media Capacity
2380 sheets
50 sheets
150 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , ADF - 80 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 31 ppm (A4) - B/W , Printing: up to 31 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex , Printing: up to 33 ppm (Letter A) - B/W , Printing: up to 33 ppm (Letter A) - colour , Printing: up to 14 spm (Letter A) - B/W duplex , Printing: up to 14 spm (Letter A) - colour duplex , Copying: up to 31 ppm - B/W , Copying: up to 31 ppm - colour , Scanning: up to 50 ppm - B/W , Scanning: up to 50 ppm - colour , Scanning: up to 100 ipm - B/W duplex , Scanning: up to 100 ipm - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB host - 4 pin USB Type A
Security Protocols & Features
Kerberos, LDAP, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, ARP, TTLS
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016
AC 230 V (50/60Hz)
580 Watt
Power Consumption Standby
70 Watt
Power Consumption Sleep
10 Watt
First Copy Out Time B/W
16 sec
First Copy Out Time Colour
17 sec
Phone cable
Consumables Included
1 x Cartridge (black) - up to 6500 pages , 1 x Cartridge (cyan) - up to 6500 pages , 1 x Cartridge (magenta) - up to 6500 pages , 1 x Cartridge (yellow) - up to 6500 pages , 1 x drum - up to 50000 pages 3 pages per job - Brother DR421CL , 1 x transfer unit - up to 130000 pages 3 pages per job , 1 x waste toner collector - up to 50000 pages - Brother WT320CL
Nordic Swan
ENERGY STAR Certified
Blue Angel Compliant
49.5 cm
52.6 cm
54.9 cm
29.7 kg
Shipping Width
67.5 cm
Shipping Depth
65.2 cm
Shipping Height
72.6 cm
Shipping Weight
36.1 kg
Sound Emission
44 dBA (idle) / 49 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Laser
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
Price Range Ex VAT: 750 - 1000
