Designed for your busy home and small offices, the affordable MFC-L3730CDN comes feature rich, with fast print speeds and built-in wired connectivity, all in a quiet and compact unit. Together with automatic 2-sided printing, you won't need to refill the paper tray as often.
- Brother MFC-L3730CDN - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Localisation
- United Kingdom
- Printing Technology
- LED (colour)
- Recommended Monthly Volume
- 300 - 1500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Copying Resolution Class
- Max Printing Speed
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Max Printing Resolution Class
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 2400 dpi
- Display
- 3.7"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 116 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN
- Office Machine Features
- Scan to e-mail, scan to FTP, scan to SMB, scan to SharePoint, scan to OCR
- Power
- AC 230 V (50/60Hz)
- 41 cm x 47.5 cm x 41.4 cm
- 23.4 kg
- 2-year warranty
- Fax Type
- Plain paper
- LED - colour
- 300 - 1500 pages
- Display Diagonal Size
- 3.7"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- USB 2.0, LAN
- Localisation
- United Kingdom
- Standard Memory
- 512 MB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, Sort
Printing
- Printer Drivers / Emulations
- PCL 6, BR-Script 3, PDF 1.7, XPS 1.0
- First Print Out Time B/W
- 15.5 sec
- First Print Out Time Colour
- 15.5 sec
- Colour Management Features
- Mopria
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
- Scanning Resolution Details
- 1200 x 2400 dpi - flatbed , 600 x 600 dpi - ADF
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Reception Memory Capacity
- Up to 500 pages
- Transmission Memory Capacity
- Up to 500 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- 250 stations
- Automatic redialing, group dialling
Document & Media Handling
- Max Original Size
- Supported Original Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), 215.9 x 300 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 116 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 150 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: 105 x 147.3 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 116 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 19 ppm (Letter A) - B/W , Printing: up to 19 ppm (Letter A) - colour , Printing: up to 6 spm (A4/Letter A) - B/W duplex , Printing: up to 6 spm (A4/Letter A) - colour duplex , Copying: up to 18 ppm - B/W , Copying: up to 18 ppm - colour , Scanning: up to 27 ipm - B/W , Scanning: up to 21 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Kerberos, SSL, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK, ARP, PEAP, EAP-FAST, EAP-MD5
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016, macOS 10.13, Windows 10 in S mode
- Voltage Required
- 400 Watt
- Power Consumption Standby
- 80 Watt
- Power Consumption Sleep
- 9.7 Watt
- First Copy Out Time B/W
- 17.5 sec
- First Copy Out Time Colour
- 17.5 sec
- Consumables Included
- 1 x Cartridge (black) - up to 1000 pages ISO/IEC 19798 , 1 x Cartridge (cyan) - up to 1000 pages ISO/IEC 19798 , 1 x Cartridge (magenta) - up to 1000 pages ISO/IEC 19798 , 1 x Cartridge (yellow) - up to 1000 pages ISO/IEC 19798 , 1 x drum - up to 18000 pages - Brother DR243CL , 1 x belt - up to 50000 pages - Brother BU223CL , 1 x waste toner collector - up to 50000 pages - Brother WT223CL
- Limited warranty - 2 years , Limited warranty - 1 year - on-site
- 41 cm
- 47.5 cm
- 41.4 cm
- 23.4 kg
- Shipping Width
- 58.9 cm
- Shipping Depth
- 52.3 cm
- Shipping Height
- 56.8 cm
- Shipping Weight
- 27.6 kg
- Sound Emission
- 43 dBA (idle) / 45 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
