Brother MFC-L2710DW MFP 1200X1200DPI
Quicklinx: DBXMWS00 Mfr#: MFCL2710DWZU1
More than 50 in stock
£101.91 ex VAT
£122.29 inc VAT
With its class-leading quietness, Brother's MFC-L2710DW can be entrusted to sit soundly in the corner of your workplace and effectively do its job. Featuring print speeds of up to 30ppm, automatic 2-sided (duplex) printing, and 250-sheet paper input, this printer is perfect for the small business that wants both efficiency and ease of use. And, with its built-in wired and wireless connectivity, the MFC-L2710DW is the multi-function that easily integrates into your working life - no worries, no fuss.
  • Print more, wait less
    Engineered for increased efficiency with class-leading print speeds of up to 32 pages per minute.
  • Dynamic features meet your evolving needs
    The 250-sheet paper capacity helps improve efficiency with less refills and handles letter and legal sized paper.
  • Flexible printing
    The manual feed slot offers flexible paper handling for a variety of papers and sizes, such as card stock, envelopes, etc. to help you create professional looking documents.
  • Engineered to deliver productivity
    Up to 50-sheet automatic document feeder helps save time with multi-page copy, scan and fax.
  • Printing as mobile as you are
    Print wirelessly from your desktop, laptop, smartphone and tablet (requires connection to a wireless network).
  • Connect your way
    Versatile connection options with built-in wireless and Ethernet network interfaces enable sharing with multiple users on your network or connect locally to a single computer via its USB interface.
  • Loaded with cost-saving features
    Automatic duplex (2-sided) printing helps save on paper costs and toner save mode helps save on toner costs.
  • Brother Genuine toner helps provide genuine savings
    Brother Genuine high-yield replacement toner delivers up to two times more prints and helps lower your printing costs.
  • Durable and dependable design
    Sturdy and robust construction ensures your all-in-one will keep up with your busy schedule.
Brother MFC-L2710DW - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
United Kingdom
Printing Technology
Laser (monochrome)
Recommended Monthly Volume
2000 pages
Max Copying Speed
Up to 30 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Copying Resolution Class
Up to 600 x 600 dpi
Max Printing Speed
Up to 30 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
120 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to SharePoint, scan to OCR, scan to image
AC 230 V (50/60Hz)
41 cm x 39.85 cm x 31.85 cm
11.8 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - monochrome
2000 pages
Display
2 lines x 16 characters
AirPrint Enabled
United Kingdom
Standard Memory
64 MB
Copying
Max Copying Speed
Up to 30 ppm
Up to 600 x 600 dpi
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Sort
Printing
Max Printing Speed
Up to 30 ppm
Printer Drivers / Emulations
Windows GDI driver
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
30-bit
Scanning Resolution Details
1200 x 1200 dpi - flatbed , 600 x 600 dpi - ADF
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 400 pages
Transmission Memory Capacity
Up to 400 pages
PC Faxing
Fax Machine Features
One-Touch Dialing
8 station(s)
Speed Dialing
200 station(s)
Broadcast Transmission
258 stations
Fax forwarding, group dialling
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
230 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
1 sheet
120 sheets
Input tray - 250 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: 105 x 147.3 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 230 g/m² , Output tray - 120 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 32 ppm (Letter A) - B/W , Printing: up to 15 spm (A4) - B/W duplex , Printing: up to 15 spm (Letter A) - B/W duplex , Scanning: up to 23.6 ipm - B/W , Scanning: up to 7.5 ipm - colour , Copying: up to 30 ppm - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
SSL, WEP, WPA-PSK, TLS, WPA2-PSK, ARP, Wi-Fi Direct
Operating System Support
Linux, MS Windows Server 2012 x64 Edition, Android, iOS, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016, macOS 10.13, Windows 10 in S mode
AC 230 V (50/60Hz)
440 Watt
Power Consumption Standby
42 Watt
Power Consumption Sleep
6.2 Watt
First Copy Out Time B/W
10 sec
Consumables Included
1 x Cartridge (black) - up to 700 pages ISO/IEC 19752 , 1 x drum (black) - up to 12000 pages - Brother DR2400
Nordic Swan Ecolabel
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 2 years , Limited warranty - 1 year - on-site
41 cm
39.85 cm
31.85 cm
11.8 kg
Shipping Width
58 cm
Shipping Depth
51.7 cm
Shipping Height
43.4 cm
Shipping Weight
14.7 kg
Sound Emission
30 dBA (idle) / 48 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
Price Range Ex VAT: 100 - 150
