Brother MFC-L2700DW Mono Laser Multfunction Printer
Quicklinx: 9NJHWS00 Mfr#: MFCL2700DWZU1
A great little network-ready mono laser printer, scanner, copier and fax for the small or home office. Speed up to 26 ppm, 250 sheet paper tray and double-sided printing as standard. Includes 35 sheet automatic document feeder.
Brother MFC-L2700DW - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 26 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 26 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
600 x 2400 dpi
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder, scan to application
AC 230 V (50/60Hz)
40.9 cm x 39.85 cm x 31.65 cm
11.4 kg
Microsoft Certification
Compatible with Windows 7
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
2 lines x 16 characters
AirPrint Enabled
Standard Memory
32 MB
Copying
Max Copying Speed
Up to 26 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Up to 26 ppm
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Scan Element
CIS
Optical Resolution
600 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
30-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Reception Memory Capacity
Up to 400 pages
Transmission Memory Capacity
Up to 400 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
8 station(s)
Speed Dialing
200 station(s)
Broadcast Transmission
258 stations
Fax forwarding, automatic redialing, group dialling, Dual Access
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
35 sheets
Max Media Size
A4/Letter
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , ADF - 35 sheets size: 147.3 x 147.3 mm - 215.9 x 355.6 mm , Bypass tray - 1 sheet size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 26 ppm (A4) - B/W , Printing: up to 13 spm (A4) - B/W duplex , Printing: up to 6.5 ppm (A4) - B/W duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, WPS, ARP, Wi-Fi Direct
Operating System Support
MS Windows Server 2003, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5, Apple Mac OS X 10.9.x
AC 230 V (50/60Hz)
480 Watt
Power Consumption Standby
2.7 Watt
Power Consumption Sleep
1.1 Watt
First Copy Out Time B/W
10 sec
Consumables Included
1 x Cartridge (black) - up to 700 pages
40.9 cm
39.85 cm
31.65 cm
11.4 kg
Sound Emission
33 dBA (idle) / 49 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
