A great little network-ready mono laser printer, scanner, copier and fax for the small or home office. Speed up to 26 ppm, 250 sheet paper tray and double-sided printing as standard. Includes 35 sheet automatic document feeder.
- Brother MFC-L2700DW - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 26 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 26 ppm
- Max Printing Resolution
- Up to 2400 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 600 x 2400 dpi
- Original Size
- 215.9 x 355.6 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to folder, scan to application
- Power
- AC 230 V (50/60Hz)
- 40.9 cm x 39.85 cm x 31.65 cm
- 11.4 kg
- Microsoft Certification
- Compatible with Windows 7
- Fax Type
- Plain paper
- Laser - monochrome
- Display
- 2 lines x 16 characters
- Interface
- AirPrint Enabled
- Standard Memory
- 32 MB
Copying
- Max Copying Speed
- Up to 26 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 26 ppm
- Image Enhancement Technology
- Brother HQ1200
- First Print Out Time B/W
- 8.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 600 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 30-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Reception Memory Capacity
- Up to 400 pages
- Transmission Memory Capacity
- Up to 400 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 8 station(s)
- Speed Dialing
- 200 station(s)
- Broadcast Transmission
- 258 stations
- Fax forwarding, automatic redialing, group dialling, Dual Access
Document & Media Handling
- Max Original Size
- 215.9 x 355.6 mm
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A4/Letter
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Input tray - 250 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , ADF - 35 sheets size: 147.3 x 147.3 mm - 215.9 x 355.6 mm , Bypass tray - 1 sheet size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 26 ppm (A4) - B/W , Printing: up to 13 spm (A4) - B/W duplex , Printing: up to 6.5 ppm (A4) - B/W duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- WEP, WPA-PSK, WPA2-PSK, WPS, ARP, Wi-Fi Direct
- Operating System Support
- MS Windows Server 2003, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5, Apple Mac OS X 10.9.x
- Voltage Required
- 480 Watt
- Power Consumption Standby
- 2.7 Watt
- Power Consumption Sleep
- 1.1 Watt
- First Copy Out Time B/W
- 10 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- 40.9 cm
- 39.85 cm
- 31.65 cm
- 11.4 kg
- Sound Emission
- 33 dBA (idle) / 49 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
