Brother MFC-J6930DW Inkjet Multifunction Printer
Quicklinx: CLMYWS00 Mfr#: MFCJ6930DWZU1
37 in stock
£253.80 ex VAT
£304.56 inc VAT
  • New build design delivers a more robust and easy to operate device suited to a busy work environment
  • A new and improved print head increases machine life and ensures exceptional durability
  • Stay prepared with a 500-sheet capacity paper tray and a 100 sheet multi-purpose tray for printing on a wide range of media
  • Enjoy fast and hassle free scanning of multi-paged documents with the 50 sheet Automatic Document Feeder
  • Reduce print costs and paper usage with automatic 2-sided print
  • Show off your sharp black text and vivid colour prints with new pigment based inks
  • Save time and money with optional high yield cartridges that deliver yields up to 3,000 mono and 1,500 colour pages
  • Stay connected with smartphone, tablet, laptop and desktop compatibility
  • With wireless and Wi-Fi Direct you don't need a router to connect
  • Scan to popular cloud storage facilities directly from the large 9.3cm intuitive swipe touchscreen
  • Capture and convert documents with ease with our exclusive Brother Cloud Apps
Brother MFC-J6930DW - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 12 ppm (mono) / up to 9 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 2400 dpi
Display
3.7"
Original Size
A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Envelopes, plain paper, recycled paper, photo paper, coated paper, glossy paper
Standard Media Capacity
600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), NFC, USB 2.0 host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive
AC 230 V (50/60Hz)
57.5 cm x 37.45 cm x 47.7 cm
23.6 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
250 - 2000 pages
Display Diagonal Size
3.7"
Display Features
Touch screen
AirPrint Enabled
Ireland
Standard Memory
256 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Nozzle Configuration
420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
1.5 pl
Automatic Duplexing
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Reception Memory Capacity
Up to 200 pages
Transmission Memory Capacity
Up to 200 pages
PC Faxing
Fax Machine Features
One-Touch Dialing
6 station(s)
Speed Dialing
200 station(s)
Broadcast Transmission
250 stations
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A3/Ledger
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, Folio (216 x 330 mm), 90 x 130 mm, 130 x 200 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
600 sheets
100 sheets
100 sheets
2 x input tray - 250 sheets - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , Bypass tray - 100 sheets - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , ADF - 50 sheets size: 105 x 148 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 90 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 22 ppm - B/W (ISO/IEC 24734) , Printing: up to 20 ppm - color (ISO/IEC 24734) , Copying: up to 12 ppm - B/W , Copying: up to 9 ppm - colour , Scanning: up to 18 ipm (A4) - B/W , Scanning: up to 18 ipm (A4) - colour , Printing: up to 12 ppm - B/W duplex (ISO/IEC 24734) , Printing: up to 11 ppm - colour duplex (ISO/IEC 24734) , Printing: up to 35 ppm - B/W fast , Printing: up to 27 ppm - colour fast , Scanning: up to 8 ipm (A3) - B/W , Scanning: up to 8 ipm (A3) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
Kerberos, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, WPS, Wi-Fi Direct
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, Apple Mac OS X 10.9, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12
AC 230 V (50/60Hz)
29 Watt
Power Consumption Standby
6.5 Watt
Power Consumption Sleep
1.7 Watt
Phone cable
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
57.5 cm
37.45 cm
47.7 cm
23.6 kg
Shipping Width
68.1 cm
Shipping Depth
50 cm
Shipping Height
56.8 cm
Shipping Weight
28.3 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
Functionality: Copier
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Max Paper Size: A3 (297 x 420 mm)
Max Paper Size: ANSI B (Ledger) (279 x 432 mm)
Brand: Brother
Price Range Ex VAT: 150 - 300
