Brother MFC J6920DW A3 Colour Inkjet All-in-One Printer with Duplex, Fax, Paper Tray and Wireless
Quicklinx: 912PWS00 Mfr#: MFCJ6920DWZU1
Our best A3 inkjet yet
The MFC-J6920DW can help your team to work faster, smarter and more collaboratively.
Connect direct to the cloud and your mobile or tablet for faster results, plus near field communication means you can print instantly by simply holding your device up to the sensor.
With double-sided printing and XL ink cartridges that offer you better value, the MFC-J6920DW cannot only streamline your working processes, but your on-going print costs as well.
Scan, copy fax and print all in one, and take advantage of a range of intelligent features to print professional A3 documents that do your hard work justice.
Key Features
  • Print, copy, scan and fax - all up to A3.
  • Up to 22ipm mono / 20ipm colour print speeds
  • Automatic 2-sided print, copy and scan
  • Wired & wireless network ready + mobile/cloud compatible + NFC
  • 6.8cm colour touchscreen
  • Up to 500 sheet paper capacity
Brother MFC-J6920DW - multifunction printer ( colour )
Fax / copier / printer / scanner
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet ( colour )
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Copying Speed
Up to 12 ppm (mono) / up to 9 ppm (colour)
Max Copying Resolution
Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
2400 x 2400 dpi
Display
3.7"
Original Size
148 x 148 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
89 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Transparencies, plain paper, photo paper, glossy paper
Standard Media Capacity
500 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
PC Connection Availability
PC Connection
USB 2.0, LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, AOSS
AC 230 V ( 50/60Hz )
55.3 cm x 43.3 cm x 31 cm
16.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified , Blue Angel
1 year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
3.7"
Display Features
Touch screen
PC Connection
AirPrint Enabled
Standard Memory
256 MB
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo, USB flash drive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Ink Type
Brother Innobella ink
Automatic Duplexing
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
2400 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grey Scale Depth
8 bit
Colour Depth
24 bit
Colour Depth (Internal)
48 bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Reception Memory Capacity
Up to 200 pages
Transmission Memory Capacity
Up to 200 pages
PC Faxing
Fax Machine Features
Broadcast Transmission
250 stations
Automatic redialing
Document & Media Handling
Min Original Size
148 x 148 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
89 x 127 mm
Max Media Size
A3/Ledger
Min Media Weight
64 g/m2
Max Media Weight
220 g/m2
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, Folio (216 x 330 mm), 127 x 203 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
500 sheets
1 sheet
50 sheets
Input tray - 250 sheets size: 210 x 279.4 mm - A3/Ledger (297 x 432 mm) , Input tray - 250 sheets size: 89 x 127 mm - A3/Ledger (297 x 432 mm) , Output tray - 50 sheets , ADF - 35 sheets size: 148 x 148 mm - A3/Ledger (297 x 432 mm) , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm)
Speed Details
Printing : up to 35 ppm - B/W , Printing : up to 27 ppm - colour , Copying : up to 9 ppm - colour (ISO/IEC 24735) , Copying : up to 12 ppm - B/W (ISO/IEC 24735) , Printing : up to 22 ppm - B/W (ISO/IEC 24734) , Printing : up to 20 ppm - color (ISO/IEC 24734)
1 x USB 2.0 - 4 PIN USB Type B , 1 x USB host - 4 PIN USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, WPS, Wi-Fi Direct
Operating System Support
MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.7.x, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 R2, MS Windows Server 2003 R2 x64 Edition, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8
Software Included
Drivers & Utilities, Brother MFL-Pro Suite, Presto! PageManager 9 for Mac, Nuance PaperPort 12 SE
29 Watt
Power Consumption Standby
5.5 Watt
Power Consumption Sleep
1.5 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x Cartridge ( black ) - up to 390 pages , 1 x Cartridge ( cyan ) - up to 390 pages , 1 x Cartridge ( magenta ) - up to 390 pages , 1 x Cartridge ( yellow ) - up to 390 pages
Blue Angel Compliant
1 year warranty
Service & Support Details
Limited warranty - 1 year - on-site
55.3 cm
43.3 cm
31 cm
16.7 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
