The all-in-one MFC-J6720DW can help to both improve productivity and reduce printing costs around your office.
Make sure your documents stand out with professional printing, copying and scanning up to A3.
Cloud-connected functions mean you can transfer to and from your mobile device to take your work with you, and also share with your colleagues via services like Dropbox and Evernote.
The MFC-J6720DW's rapid print speeds mean you won't have to wait for your documents, while the extra paper tray means less time refilling the machine for those bigger jobs.
Plus cost-saving features like double-sided printing and 'Ink Save' mode allow you to easily keep a tighter rein on your printing spends.
- Brother MFC-J6720DW - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Max Copying Speed
- Up to 12 ppm (mono) / up to 9 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 20 ppm (colour)
- Max Printing Resolution
- Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 2400 x 2400 dpi
- Display
- 2.7"
- Original Size
- 297 x 431.8 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 89 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, photo paper, coated paper, glossy paper
- Standard Media Capacity
- 500 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, AOSS, scan to Cloud
- Power
- AC 230 V (50/60Hz)
- 55.3 cm x 43.3 cm x 31 cm
- 16.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Diagonal Size
- 2.7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 128 MB
- Supported Flash Memory
- SD Memory Card, MultiMediaCard, Memory Stick Duo, USB flash drive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Nozzle Configuration
- 420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Type
- Brother Innobella ink
Scanning
- Optical Resolution
- 2400 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Reception Memory Capacity
- Up to 200 pages
- Transmission Memory Capacity
- Up to 200 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 200 station(s)
- Caller ID
- Telephone / Fax Switch
- Broadcast Transmission
- 250 stations
- Fax forwarding, group dialling, Dual Access, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
- Max Original Size
- 297 x 431.8 mm
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, Folio (216 x 330 mm), 127 x 203 mm, 89 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 500 sheets
- 1 sheet
- 50 sheets
- Input tray - 250 sheets size: 89 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , ADF - 35 sheets size: 148 x 148 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 90 g/m² , Output tray - 50 sheets , Input tray - 250 sheets size: 210 x 279.4 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 105 g/m²
- Speed Details
- Printing: up to 35 ppm - B/W , Printing: up to 27 ppm - colour , Printing: up to 22 ipm - B/W (ISO/IEC 24734) , Printing: up to 20 ipm - colour (ISO/IEC 24734) , Copying: up to 23 ppm - B/W , Copying: up to 20 ppm - colour , Copying: up to 12 ipm - B/W (ISO/IEC 24735) , Copying: up to 9 ipm - colour (ISO/IEC 24735)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- WEP, WPA-PSK, WPA2-PSK, TKIP, AES, WPS, ARP, Wi-Fi Direct
- Operating System Support
- MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.7.x, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2003 R2, MS Windows Server 2003 R2 x64 Edition, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6.8
- Software Included
- Brother ControlCentre2, Brother MFL-Pro Suite, Brother ControlCenter4, Presto! PageManager 9 for Mac, Nuance PaperPort 12 SE
- Voltage Required
- 28 Watt
- Power Consumption Standby
- 5.5 Watt
- Power Consumption Sleep
- 1.5 Watt
- Direct Printing Specifications
- PictBridge
- Included Accessories
- Phone cable, A3 paper sample pack
- Consumables Included
- 1 x ink cartridge (black) - up to 600 pages - Brother Innobella LC123BK , 1 x ink cartridge (cyan) - up to 600 pages - Brother Innobella LC123C , 1 x ink cartridge (magenta) - up to 600 pages - Brother Innobella LC123M , 1 x ink cartridge (yellow) - up to 600 pages - Brother Innobella LC123Y
- ENERGY STAR Certified
- 55.3 cm
- 43.3 cm
- 31 cm
- 16.7 kg
- Shipping Width
- 65.7 cm
- Shipping Depth
- 52.1 cm
- Shipping Height
- 41.4 cm
- Shipping Weight
- 20.8 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
