Brother MFC-J5720DW Colour Inkjet Multifunction Printer
Quicklinx: 9SVCWS00 Mfr#: MFC-J5720DWZU1
Inkjet All In One with Fax & A3 Print
Fast Colour Printing
  • Help increase office productivity with print speeds of up to 20ipm colour and 22ipm mono
Colour Touchscreen Display
  • Easy navigation and menu selection via the 9.3cm colour LCD touchscreen
Automatic 2-Sided
  • Create 2-sided documents to reduce paper consumption when printing copying, scanning, and faxing
Built-in Wi-Fi Networking
  • Share with your workgroup via its built-in wireless 802.11b/g/n network interface
Paper Input
  • Additional 250 sheet lower tray giving a total paper input of 580 sheets
High Yield Replacement Cartridges
  • Help lower your operating costs with optional high yield replacement cartridges
High Quality A3 Output
  • Print professional colour documents with output up to 6,000 x 1,200dpi resolution10 and up to A3 in size
Mobile Printing & Scanning
  • Support for Brother iPrint&Scan, Google Cloud Print6, Apple AirPrint
Advanced Fax Capabilities
  • 14.4Kbps modem, PC-Fax Send8&3, PC-Fax Receive8&4 and Internet Fax5 (Ifax)
Rear Multi Purpose Tray
  • Flexible paper handling with an 80 Sheet multipurpose paper tray
Brother MFC-J5720DW - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 12 ppm (mono) / up to 9 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Up to 22 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
2400 x 2400 dpi
Display
3.7"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
89 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Envelopes, plain paper, coated paper, glossy paper
Standard Media Capacity
580 sheets
Bypass Feeder Capacity
80 sheets
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, AOSS
AC 230 V (50/60Hz)
49 cm x 34.5 cm x 30.8 cm
14.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
3.7"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Nozzle Configuration
420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Ink Type
Brother Innobella ink
Automatic Duplexing
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
2400 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Reception Memory Capacity
Up to 200 pages
Transmission Memory Capacity
Up to 200 pages
PC Faxing
Fax Machine Features
Caller ID
Telephone / Fax Switch
Broadcast Transmission
250 stations
Automatic redialing, colour faxing, Distinctive Ring Detection (DRD), fax memory backup
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
89 x 127 mm
Max Media Size
A3/Ledger
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, Folio (216 x 330 mm), 127 x 203 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 89 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
580 sheets
80 sheets
50 sheets
Input tray - 250 sheets size: 89 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , Input tray - 250 sheets size: A4 (210 x 297 mm) - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 120 g/m² , Bypass tray - 80 sheets size: 89 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , ADF - 50 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m²
Speed Details
Printing: up to 35 ppm - B/W , Printing: up to 27 ppm - colour , Printing: up to 22 ppm - B/W (ISO/IEC 24734) , Printing: up to 20 ppm - colour (ISO/IEC 24734) , Copying: up to 12 ppm - B/W (ISO/IEC 24735) , Copying: up to 9 ppm - colour (ISO/IEC 24735)
1 x USB 2.0 , 1 x USB host , 1 x LAN
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, WPS, ARP
Operating System Support
MS Windows XP Professional x64 Edition, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Windows 8.1, Windows 8.1 64-bit, Apple Mac OS X 10.7.5, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits)
AC 230 V (50/60Hz)
32 Watt
Power Consumption Standby
5.5 Watt
Power Consumption Sleep
1.8 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
Blue Angel Compliant
49 cm
34.5 cm
30.8 cm
14.5 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
