Stay productive with fast print speeds, wired and wireless connectivity and professional quality printing.
- New build design delivers a more robust and easy to operate device suited to a busy work environment
- A new and improved print head increases machine life and ensures exceptional durability
- Stay prepared with a 250-sheet capacity paper tray and a rear manual feed slot for printing on a wide range of media
- Enjoy fast and hassle free scanning of multi-paged documents with the 50 sheet Automatic Document Feeder
- Reduce print costs and paper usage with automatic 2-sided print
- With new pigment based inks you can enjoy professional quality prints with sharp black text and vivid colour documents
- Save time and money with optional high yield cartridges that deliver yields up to 3,000 mono and 1,500 colour pages
- Stay connected with smartphone, tablet, laptop and desktop compatibility
- With wireless and Wi-Fi Direct you don't need a router to connect
- Scan to popular cloud apps directly from the large 6.8cm intuitive swipe touchscreen
- Capture and convert documents with ease with our exclusive Brother Cloud Apps
- Brother MFC-J5330DW - multifunction printer - colour
- Multifunction printer
- Fax Type
- G3 - plain paper
- Localisation
- Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2000 pages
- Max Copying Speed
- Up to 12 ppm (mono) / up to 9 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 22 ppm 27 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 14.4 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 2400 dpi
- Display
- 2.7"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Envelopes, plain paper, recycled paper, coated paper, glossy paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to SharePoint
- Power
- AC 230 V (50/60Hz)
- 53 cm x 39.8 cm x 30.4 cm
- 16.9 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 pages
- 250 - 2000 pages
- Display Diagonal Size
- 2.7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Ireland
- Standard Memory
- 128 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Nozzle Configuration
- 420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 1.5 pl
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 16-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- G3
- Max Transmission Speed
- 14.4 Kbps
- Fax Resolutions
- Reception Memory Capacity
- Up to 200 pages
- Transmission Memory Capacity
- Up to 200 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Broadcast Transmission
- 250 stations
- Automatic redialing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A3/Ledger
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, Folio (216 x 330 mm), 90 x 130 mm, 130 x 200 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Input tray - 250 sheets - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , ADF - 50 sheets size: 105 x 148 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Output tray - 100 sheets , Bypass tray - 1 sheet - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m²
- Speed Details
- Printing: up to 35 ppm - B/W , Printing: up to 27 ppm - colour , Printing: up to 22 ipm - B/W (ISO/IEC 24734) , Printing: up to 20 ipm - colour (ISO/IEC 24734) , Copying: up to 12 ipm - B/W , Copying: up to 9 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- Kerberos, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TTLS, PEAP
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, Apple Mac OS X 10.9, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12
- Voltage Required
- 29 Watt
- Power Consumption Standby
- 6.5 Watt
- Power Consumption Sleep
- 1.6 Watt
- Consumables Included
- 1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 53 cm
- 39.8 cm
- 30.4 cm
- 16.9 kg
- Shipping Width
- 63.7 cm
- Shipping Depth
- 46.7 cm
- Shipping Height
- 43.7 cm
- Shipping Weight
- 20.5 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
