Product
Brother MFC-J480DW Compact Inkjet Multifunction Printer
Quicklinx: CLLRWS00 Mfr#: MFCJ480DWZU1
High-quality colour print, scan, copy and fax from the compact home inkjet with huge potential. Accessible and affordable, this easy to use machine effortlessly fits into your home and offers great value for money.
  • Fast and high-quality colour print
  • 4.5cm LCD screen
  • Built-in wireless and mobile and cloud connectivity
  • Our lowest ever replacement ink costs
  • 20 sheet automatic document feeder
High-quality colour printing from home. The MFC-J480DW provides full colour print, copy, scan and fax in a compact all-in-one home inkjet printer.
Printing paperwork, homework or important documents can be achieved quickly and efficiently with fast print speeds, while making copies and scanning photos or documents of varying sizes is made effortless with a 20 sheet automatic document feeder.
The 4.5cm LCD screen and panel buttons makes menu selection simple and navigation easy. Scan photos and documents in seconds, direct to cloud and mobile services such as Facebook, OneDrive, Google Drive and Dropbox. Print directly from your smartphone or tablet device via apps including Apple AirPrint, Google Cloud Print and Brother’s Free iPrint&Scan app.
Using your home’s wireless network, the MFC-J480DW can integrate seamlessly into your daily life. Print and scan to and from your mobile device, and press print from anywhere in the house, retrieving your documents when it’s convenient.
Brother MFC-J480DW - multifunction printer (colour)
Multifunction printer
Fax Type
G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 6 ppm (mono) / up to 3 ppm (colour)
Max Copying Resolution
Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
Max Printing Speed
Up to 12 ppm (mono) / up to 6 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Max Fax Transmission Speed
14.4 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 2400 dpi
Display
1.8"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper, coated paper, glossy paper
Standard Media Capacity
100 sheets
Max Media Capacity
100 sheets
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to folder, scan to network, scan to OCR
AC 230 V (50/60Hz)
40 cm x 34.1 cm x 17.2 cm
8.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
1.8"
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Standard Memory
128 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Nozzle Configuration
210 nozzles (black), 3 x 70 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Automatic Duplexing
Scanning
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
30-bit
Fax Machine
Compatibility
G3
Max Transmission Speed
14.4 Kbps
Fax Resolutions
Reception Memory Capacity
Up to 170 pages
Transmission Memory Capacity
Up to 170 pages
Fax Machine Features
Speed Dialing
40 station(s)
Broadcast Transmission
90 stations
Document & Media Handling
Max Original Size
Original Type
Sheets
20 sheets
Max Media Size
A4/Letter
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 127 x 203 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
100 sheets
Max Media Capacity
100 sheets
50 sheets
Input tray - 100 sheets , ADF - 20 sheets , Output tray - 50 sheets
Speed Details
Printing: up to 12 ipm - B/W (ISO/IEC 24734) , Printing: up to 6 ipm - color (ISO/IEC 24734) , Scanning: 3.37 sec - B/W , Scanning: 4.27 sec - colour , Copying: up to 6 ipm - B/W (ISO/IEC 24734) , Copying: up to 3 ipm - color (ISO/IEC 24734)
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, AES, ARP
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, MS Windows Server 2012 R2, Apple Mac OS X 10.8.5, Apple Mac OS X 10.9.x, Apple Mac OS X 10.10.x
Software Included
Brother ControlCentre2, Brother ControlCenter4, Nuance PaperPort 14 SE with OCR
AC 230 V (50/60Hz)
19 Watt
Power Consumption Standby
3.5 Watt
Power Consumption Sleep
1.1 Watt
Nordic Swan
ENERGY STAR Certified
Blue Angel Compliant
40 cm
34.1 cm
17.2 cm
8.3 kg
Shipping Width
44.7 cm
Shipping Depth
24.9 cm
Shipping Height
45.7 cm
Shipping Weight
10.1 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
