High-quality colour print, scan, copy and fax from the compact home inkjet with huge potential. Accessible and affordable, this easy to use machine effortlessly fits into your home and offers great value for money.
- Fast and high-quality colour print
- 4.5cm LCD screen
- Built-in wireless and mobile and cloud connectivity
- Our lowest ever replacement ink costs
- 20 sheet automatic document feeder
High-quality colour printing from home. The MFC-J480DW provides full colour print, copy, scan and fax in a compact all-in-one home inkjet printer.
Printing paperwork, homework or important documents can be achieved quickly and efficiently with fast print speeds, while making copies and scanning photos or documents of varying sizes is made effortless with a 20 sheet automatic document feeder.
The 4.5cm LCD screen and panel buttons makes menu selection simple and navigation easy. Scan photos and documents in seconds, direct to cloud and mobile services such as Facebook, OneDrive, Google Drive and Dropbox. Print directly from your smartphone or tablet device via apps including Apple AirPrint, Google Cloud Print and Brother’s Free iPrint&Scan app.
Using your home’s wireless network, the MFC-J480DW can integrate seamlessly into your daily life. Print and scan to and from your mobile device, and press print from anywhere in the house, retrieving your documents when it’s convenient.
- Brother MFC-J480DW - multifunction printer - colour
- Multifunction printer
- Fax Type
- G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Max Copying Speed
- Up to 6 ppm (mono) / up to 3 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
- Max Printing Speed
- Up to 12 ppm (mono) / up to 6 ppm (colour)
- Max Printing Resolution
- Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 14.4 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 2400 dpi
- Display
- 1.8"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 20 sheets
- Media Size
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, recycled paper, coated paper, glossy paper
- Standard Media Capacity
- 100 sheets
- Max Media Capacity
- 100 sheets
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to folder, scan to network, scan to OCR
- Power
- AC 230 V (50/60Hz)
- 40 cm x 34.1 cm x 17.2 cm
- 8.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Diagonal Size
- 1.8"
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Standard Memory
- 128 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Nozzle Configuration
- 210 nozzles (black), 3 x 70 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
Scanning
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 30-bit
Fax Machine
- Compatibility
- G3
- Max Transmission Speed
- 14.4 Kbps
- Fax Resolutions
- Reception Memory Capacity
- Up to 170 pages
- Transmission Memory Capacity
- Up to 170 pages
Fax Machine Features
- Speed Dialing
- 40 station(s)
- Broadcast Transmission
- 90 stations
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 20 sheets
- Max Media Size
- A4/Letter
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 127 x 203 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 100 sheets
- 100 sheets
- 50 sheets
- Input tray - 100 sheets , ADF - 20 sheets , Output tray - 50 sheets
- Speed Details
- Printing: up to 12 ipm - B/W (ISO/IEC 24734) , Printing: up to 6 ipm - colour (ISO/IEC 24734) , Scanning: 3.37 sec - B/W , Scanning: 4.27 sec - colour , Copying: up to 6 ipm - B/W (ISO/IEC 24734) , Copying: up to 3 ipm - colour (ISO/IEC 24734)
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK, AES, ARP
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, MS Windows Server 2012, Windows 8, MS Windows Server 2012 R2, Apple Mac OS X 10.8.5, Apple Mac OS X 10.9.x, Apple Mac OS X 10.10.x
- Software Included
- Brother ControlCentre2, Brother ControlCenter4, Nuance PaperPort 14 SE with OCR
- Voltage Required
- 19 Watt
- Power Consumption Standby
- 3.5 Watt
- Power Consumption Sleep
- 1.1 Watt
- Nordic Swan
- ENERGY STAR Certified
- Blue Angel Compliant
- 40 cm
- 34.1 cm
- 17.2 cm
- 8.3 kg
- Shipping Width
- 44.7 cm
- Shipping Depth
- 24.9 cm
- Shipping Height
- 45.7 cm
- Shipping Weight
- 10.1 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
