Brother MFC-J4620DW Colour Inkjet Multifunction Printer
Quicklinx: 9T01WS00 Mfr#: MFCJ4620DWZU1
Inkjet All In One with Fax & A3 Print
Fast Colour Printing
  • Help increase office productivity with print speeds of up to 20ipm colour and 22ipm mono
High Yield Replacement Cartridges
  • Help lower your operating costs with optional high yield replacement cartridges
Large Colour Touchscreen Display
  • Easy navigation and menu selection via the 9.3cm colour LCD Touchscreen
Automatic 2-Sided Printing
  • Create 2-sided documents to reduce paper consumption
Built-in Networking
  • Share with your workgroup via its built-in wireless 802.11b/g/n and wired network interface
Automatic document feeder
  • 20 sheet automatic document feeder (ADF) for copy, scan and fax
High Quality Occasional A3 Output
  • Print professional colour documents with output up to 6,000 x 1,200dpi resolution10 and up to A3 in size
Mobile Printing & Scanning
  • Support for Brother iPrint&Scan, Google Cloud Print6,
Cloud Services
  • Scan to and print from Google Docs, Evernote, Facebook, Flickr,Picassa, Dropbox, Onedrive & Box Apple AirPrint and Cortado WorkPlace®6
Advanced Fax Capabilities
  • 14.4Kbps modem, PC-Fax Send8&3, PC-Fax Receive8&4 and Internet Fax5 (Ifax)
  • Low cost printing
    Super High-yield replacement ink cartridges.
  • Fastest in class
    With speeds up to 35ppm black and 27ppm color. ISO print speeds up to 22ppm black and 20ppm color.
  • Wireless mobile device printing
    Wireless printing from your mobile device via: AirPrint, Google Cloud Print, Brother iPrint&Scan, Cortado Workplace and Wi-Fi Direct.
  • NFC capability
    "Touch to connect" printing and scanning from NFC-capable devices.
  • Intuitive TouchScreen
    Display Easily navigate onscreen menus on a 3.7" TouchScreen Display with swipe functionality.
  • Paper handling
    150-sheet capacity paper tray and up to 20-sheet ADF. Also includes a single-sheet bypass tray.
  • Innovative print technology
    Landscape Print Technology stores and feeds paper in a landscape orientation for a space saving design.
Brother MFC-J4620DW - multifunction printer - colour
Multifunction printer
Fax Type
G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 12 ppm (mono) / up to 9 ppm (colour)
Max Copying Resolution
Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
Max Printing Speed
Up to 35 ppm (mono) / up to 27 ppm (colour)
Max Printing Resolution
Up to 1200 x 6000 dpi (mono) / up to 1200 x 6000 dpi (colour)
Max Fax Transmission Speed
14.4 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
2400 x 2400 dpi
Display
3.7"
Original Size
148 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
89 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Envelopes, plain paper, photo paper, coated paper, glossy paper
Standard Media Capacity
150 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to network, AOSS
AC 230 V (50/60Hz)
48 cm x 29 cm x 18.8 cm
9.5 kg
Microsoft Certification
Compatible with Windows 7
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
3.7"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
128 MB
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Nozzle Configuration
420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
2400 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
G3
Max Transmission Speed
14.4 Kbps
Fax Resolutions
Reception Memory Capacity
Up to 200 pages
Transmission Memory Capacity
Up to 200 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Broadcast Transmission
250 stations
Automatic redialing, colour faxing, group dialling
Document & Media Handling
Min Original Size
148 x 148 mm
Max Original Size
Original Type
Sheets
20 sheets
Min Media Size
89 x 127 mm
Max Media Size
A3/Ledger
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, 127 x 203 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 89 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
150 sheets
1 sheet
50 sheets
Input tray - 150 sheets size: 89 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , ADF - 20 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Output tray - 50 sheets
Speed Details
Printing: up to 22 ipm - B/W , Printing: up to 20 ipm - colour , Printing: up to 35 ppm - B/W , Copying: up to 27 ppm - colour , Copying: up to 12 ppm - B/W , Copying: up to 9 ppm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5, Apple Mac OS X 10.9.x
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
32 Watt
Power Consumption Standby
5.5 Watt
Power Consumption Sleep
1.9 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
48 cm
29 cm
18.8 cm
9.5 kg
Shipping Width
56.9 cm
Shipping Depth
39.8 cm
Shipping Height
26.5 cm
Shipping Weight
11.9 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
