Brother MFC-J4420DW Colour Inkjet Multifunction Printer
Quicklinx: 9T04WS00 Mfr#: MFCJ4420DWZU1
It's easy to connect to the MFC-J4420DW from your PC, laptop or mobile device thanks to its integrated wireless networking, allowing any users in your office or home to print, copy, scan and fax with ease.
The 6.8cm colour touchscreen lets you connect to popular cloud platform such as Facebook, Google Drive and Dropbox. While you can manage your documents more effectively with features such as A3 printing, 2-sided print (up to A4), easy scanning and copying, and an integrated 20 sheet automatic document feeder.
The optional high-yield ink cartridges can also help lower your printing costs compared to standard yield ink. And rest assured the MFC-J4420DW complies with the strict ENERGY STAR, German Blue Angel and Nordic Swan environmental standards.
  • Wireless mobile device printing
    Wireless printing from your mobile device via: AirPrint, Google Cloud Print, Brother iPrint&Scan, Cortado Workplace and Wi-Fi Direct.
  • TouchScreen display
    Easily navigate onscreen menus on TouchScreen display.
  • Innovative print technology
    Landscape print technology stores and feeds paper in a landscape orientation for a space saving design.
  • Web connect
    Scan to popular cloud services including Google Drive, Dropbox, Evernote and Evernote Business, Microsoft OneNote and more.
Brother MFC-J4420DW - multifunction printer - colour
Multifunction printer
Fax Type
G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 12 ppm (mono) / up to 9 ppm (colour)
Max Copying Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Printing Speed
Up to 20 ppm (mono) / up to 18 ppm (colour)
Max Printing Resolution
Up to 1200 x 6000 dpi (mono) / up to 1200 x 6000 dpi (colour)
Max Fax Transmission Speed
14.4 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
Scanning
1200 x 2400 dpi
Display
2.7"
Original Size
148 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
89 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Envelopes, plain paper, photo paper, coated paper, glossy paper
Standard Media Capacity
150 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to network, AOSS
AC 230 V (50/60Hz)
48 cm x 29 cm x 18.8 cm
9.5 kg
Microsoft Certification
Compatible with Windows 7
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Diagonal Size
2.7"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
128 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Nozzle Configuration
420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
1.5 pl
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
G3
Max Transmission Speed
14.4 Kbps
Fax Resolutions
Reception Memory Capacity
Up to 200 pages
Transmission Memory Capacity
Up to 200 pages
PC Faxing
Fax Machine Features
Broadcast Transmission
250 stations
Automatic redialing, colour faxing, group dialling
Document & Media Handling
Min Original Size
148 x 148 mm
Max Original Size
Original Type
Sheets
20 sheets
Min Media Size
89 x 127 mm
Max Media Size
A3/Ledger
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, 127 x 203 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 89 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
150 sheets
1 sheet
50 sheets
Input tray - 150 sheets size: 89 x 127 mm - A3/Ledger (297 x 432 mm) , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm) , ADF - 20 sheets size: 148 x 148 mm - Legal (216 x 356 mm) , Output tray - 50 sheets
Speed Details
Printing: up to 20 ppm - B/W , Printing: up to 18 ppm - colour , Printing: up to 6 ppm - B/W duplex , Printing: up to 6 ppm - colour duplex , Copying: up to 12 ppm - B/W , Copying: up to 9 ppm - colour , Scanning: 3.34 sec (A4) - B/W , Scanning: 4.15 sec (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2003 R2, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Windows 8.1, MS Windows Server 2012 R2, Apple Mac OS X 10.7.5, Apple Mac OS X 10.9.x
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
23 Watt
Power Consumption Standby
5 Watt
Power Consumption Sleep
1.7 Watt
Direct Printing Specifications
PictBridge
Phone cable
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
48 cm
29 cm
18.8 cm
9.5 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
