Work more efficiently with the MFC-8950DWT multifunction printer.
This robust, machine – a heavyweight performer in any demanding office – offers a high speed output at up to 40ppm, up to 12,000 page super high-yield toner cartridges and an intuitive touchscreen. Automatic duplex printing – plus duplex copy, scan and fax – and a standard paper tray capacity of 1,050 sheets means you'll spend less time waiting for your printouts and also won't have to refill so often.
The MFC-8950DWT also has a range of energy saving functions, including toner save and deep sleep modes, which ensure your business enjoys both reduced costs and a smaller carbon footprint.
- Brother MFC-8950DWT - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Recommended Monthly Volume
- 5000 pages
- Max Copying Speed
- Up to 40 ppm
- Max Copying Resolution
- Up to 1200 x 600 dpi
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG, JPEG
- Scanning
- 1200 x 1200 dpi
- Display
- 5"
- Original Size
- 147.3 x 147.3 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
- Standard Media Capacity
- 1050 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, AOSS
- Power
- AC 230 V (50/60Hz)
- 49.1 cm x 41.5 cm x 60.7 cm
- 20.8 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - monochrome
- 5000 pages
- Display Diagonal Size
- 5"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 128 MB 128 MB
- Max Supported Memory
- 384 MB 384 MB
Copying
- Max Copying Speed
- Up to 40 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Sort
Printing
- Up to 40 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, IBM Proprinter, BR-Script 3
- Image Enhancement Technology
- Brother HQ1200
- First Print Out Time B/W
- 8.5 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Reception Memory Capacity
- Up to 500 pages
- Transmission Memory Capacity
- Up to 500 pages
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 32 station(s)
- Speed Dialing
- 300 station(s)
- Broadcast Transmission
- 382 stations
- Delayed Transmission
- Remote Fax Retrieval (Polling)
- Fax forwarding, automatic redialing, group dialling, Dual Access, auto reduction
Document & Media Handling
- Min Original Size
- 147.3 x 147.3 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
- 1050 sheets
- 50 sheets
- 150 sheets
- ADF - 50 sheets size: 147.3 x 147.3 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , 2 x input tray - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 40 ppm (A4) - B/W , Printing: up to 18 spm (A4) - B/W duplex , Copying: up to 40 ppm - B/W
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Network Protocols
- TCP/IP, IPP, LPR/LPD, RAW IP (Port 9100), SNMP, HTTP, HTTPS, IPv4, IPv6, FTP, SMTP, DHCP, BOOTP, RARP, NetBIOS
- LDAP, Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, WPS, ARP, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows Server 2003, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista, MS Windows 2000 Professional, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, Apple Mac OS X 10.7.x
- Software Included
- Drivers & Utilities, Brother BR-Admin Professional, Brother BR-Admin Light for Linux & Macintosh
- Voltage Required
- 694 Watt
- Power Consumption Standby
- 9.8 Watt
- Power Consumption Sleep
- 6.8 Watt
- First Copy Out Time B/W
- 10.5 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 8000 pages , 1 x drum - up to 30000 pages - Brother DR3300
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 49.1 cm
- 41.5 cm
- 60.7 cm
- 20.8 kg
- Shipping Width
- 76.4 cm
- Shipping Depth
- 56.3 cm
- Shipping Height
- 92.4 cm
- Shipping Weight
- 35.2 kg
- Sound Emission
- 37 dBA (idle) / 59 dBA (operating)
- 10 °C
- 32.5 °C
- 20 - 80% (non-condensing)
Brother HL5100 Series Drum Unit | In Stock | £132.91 |
Brother TN3330 Toner Cartridge - Black | In Stock | £57.26 |
Brother TN3380 Black Toner Cartridge | In Stock | £90.22 |
Brother TN3390 Toner Cartridge - Black | In Stock | £101.69 |
