Brother HLL6400 Mono Laser Printer
Quicklinx: C143WS00 Mfr#: HLL6400DWZU1
Type: Printer
Functionality: Printer
Wireless Capability: Wired, Wireless
Max Paper Size: A4 (210 x 297 mm), Legal (216 x 356 mm)
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
More than 50 in stock
£423.36 ex VAT
£508.03 inc VAT
Open up new business opportunities with this robust machine. Offering excellent paper handling options, super fast print speeds and the new optional ultra-high-yield toner cartridges significantly reduces your print spend, making this machine the ideal print partner for your business.
Key Features
  • Super-fast print speeds of up to 50ppm.
  • Outstanding paper handling options with a standard paper capacity of 570 sheets expandable to 2,650 sheets.
  • 12,000 page inbox toner & optional ultra high yield 20,000 page toner cartridge.
  • Intuitive 4.5cm touchscreen LCD display.
  • Integrated NFC Reader, giving users better document security and improved user authentication for pull printing.
Maximise Performance & Reduce Print Spend
Versatile paper handling, enables you to add multiple lower trays, and mailbox options across the range. This provides maximum device uptime, as less time is spent replenishing paper trays and searching for your printed documents. With the optional ultra high yield toner cartridges, productivity is enhanced, whilst reducing your overall printing costs.
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L6000 range has been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Enhanced Workflow
The L6000 range introduces an intuitive and user-friendly interface, and support for multiple business cloud based services including Dropbox and Google Drive.
Tighter security
In today's business environment, we understand that organisations demand the highest levels of security. In order to address this, the L6000 range is enabled with secure function lock 3.0, 802.1x and Internet Protocol Security (IPsec). The range also boasts Print Archive, Secure Reset, Certificate Management and Near field communication (NFC) functionality for secure user access and authentication.
Flexible print solutions from Brother
Our L6000 range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions enables you to maximise your print efficiency and minimise costs, specifically tailored to your requirements.
Eco-friendly
The L6000 range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
  • Maximize performance
    Significantly increase your workgroup productivity thanks to super-fast print speeds. Maximize performance with high speed wired and wireless network interfaces. Streamline workflows and easily print with NFC technology. The incredible easy-to-use touchscreen user interface allows users to complete tasks with no hassle.
  • Exceptionallly low running costs
    It is not just equipped with features provided to turn heads. Designed for demanding high-volume print environments, the HL-L6400DW features a high-yield toner cartridge to lower your running costs even further.
Brother HL-L6400DW - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
13.4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 52 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 50 ppm - B/W - A4 (210 x 297 mm) , Up to 24 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 24 ppm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
Preview Screen Size
1.8"
Cortex-A9 800 MHz
RAM Installed (Max)
512 MB
Language Simulation
PostScript 3, PCL 6, XPS, IBM ProPrinter XL, EPSON FX-850, PDF 1.7
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper
Total Media Capacity
570 sheets
Media Handling
50-sheet multipurpose tray, 520-sheet input tray
Recommended Monthly Volume
10000 pages
Print server
AC 230V
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Apple MacOS X 10.8, Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Apple MacOS X 10.11
40 cm x 28.8 cm x 39.6 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
1.8"
Wireless
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
7.5 sec
Language Simulation
Media Handling
Cortex-A9 800 MHz
RAM
RAM Installed (Max)
512 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
Media Weight
60 g/m² - 200 g/m²
570 sheets
Media Feeders
1 x automatic - 520 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m²
Output Trays Capacity
250 sheets
Duty Cycle
10000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, SSL, TLS, IPsec, 802.1x, ARP, PEAP
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 12000 pages
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
770 Watt
Power Consumption Stand by
32 Watt
Power Consumption Sleep
7.3 Watt
Environmental Standards
Blue Angel
ENERGY STAR
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
35 dBA
Sound Emission (Operating)
54 dBA
Sound Emission (Quiet Mode)
50 dBA
40 cm
28.8 cm
39.6 cm
13.4 kg
Width (Shipping)
49.7 cm
Depth (Shipping)
49.2 cm
Height (Shipping)
53.1 cm
Weight (Shipping)
16 kg
Type: Printer
Wireless Capability: Wireless
Brand: Brother
Price Range Ex VAT: 300 - 500
