Your basket is empty
Brother HLL5100DN Mono Laser Printer
Quicklinx: C2S4WS00 Mfr#: HL-L5100DN
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Laser
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
More than 50 in stock
£163.61 ex VAT
£196.33 inc VAT
The Brother L5100DN laser printer is perfect for offices and small workgroups looking for quality and reliability. It delivers cost-efficient, two-sided output thanks to a high-yield replacement toner cartridge. Plus, it quickly prints high-quality business documents. Advanced security features help protect your sensitive documents and the printer from unauthorized access.
Key Features
  • Fast print speeds of up to 40ppm.
  • Combined paper input of 300 sheets.
  • Automatic 2-sided printing.
  • High-yield replacement cartridges - optional high yield 8,000 (approx) page toner cartridge.
  • 1 line, 16 character backlit LCD display.
  • High speed wired (10Base-T/100Base-TX/) and USB 2.0 connectivity.
Maximise Performance & Reduce Print Spend
Versatile paper handling enables you to add multiple lower trays across the range. This provides maximum device uptime, as less time is spent replenishing paper trays. With the optional high yield toner cartridges, productivity is enhanced whilst reducing your overall printing costs.
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L5000 range has been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Tighter security
In today's business environment, we understand that organisations demand the highest levels of security. In order to address this, the L5000 range is enabled with secure function lock 3.0, 802.1x network security and Internet Protocol Security (IPsec). The range also boasts Print Archive, Secure Reset and Certificate Management.
Flexible print solutions from Brother
Our L5000 range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions can be specifically tailored to your requirements and enables you to maximise your print efficiency and minimise costs.
Eco-friendly
The L5000 range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
Brother HL-L5100DN - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
10.7 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 42 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 20 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 20 ppm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN
Cortex-A9 800 MHz
RAM Installed (Max)
256 MB
Language Simulation
PCL 6, XPS, BR-Script3, IBM ProPrinter XL, EPSON FX-850, PDF 1.7
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Print server
AC 230V
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Apple MacOS X 10.8, Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Apple MacOS X 10.11
37.3 cm x 38.8 cm x 25.5 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB 2.0, LAN
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7.2 sec
Language Simulation
Media Handling
Cortex-A9 800 MHz
RAM
RAM Installed (Max)
256 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
Media Weight
60 g/m² - 200 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m²
Output Trays Capacity
150 sheets
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, SSL, TLS, IPsec, 802.1x, ARP, PEAP
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Nordic Swan
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
640 Watt
Power Consumption Stand by
32 Watt
Power Consumption Sleep
6.5 Watt
Environmental Standards
Blue Angel
ENERGY STAR
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
34 dBA
Sound Emission (Operating)
52 dBA
Sound Emission (Quiet Mode)
50 dBA
37.3 cm
38.8 cm
25.5 cm
10.7 kg
Width (Shipping)
48.5 cm
Depth (Shipping)
45 cm
Height (Shipping)
37.7 cm
Weight (Shipping)
13 kg
Type: Printer
Technology: Laser
Brand: Brother
Price Range Ex VAT: 150 - 300
