The sleek HL-3150CDW is packed with great features designed to meet the demands of your busy office.
Fast, efficient and reliable, this compact printer offers low energy consumption, plus double-sided printing and optional high-yield colour toner cartridges to keep costs down.
Get connected quickly, and easily save and share resources across your network thanks to built-in wireless functionality. You can even print direct from your mobile device with Apple AirPrint or Google Cloud Print .
And, most importantly of all, the colour HL-3150CDW makes your ideas look brighter, so your business always stands out.
- Brother HL-3150CDW - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 17.8 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 116 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 18 ppm - colour - A4 (210 x 297 mm) , Up to 19 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 19 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 7 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 7 spm - colour duplex - ANSI A (Letter) (216 x 279 mm) , Up to 7 spm - B/W duplex - A4 (210 x 297 mm) , Up to 7 spm - colour duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 600 x 2400 dpi
- Max Resolution (Colour)
- 600 x 2400 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- RAM Installed (Max)
- 64 MB
- Language Simulation
- Windows GDI driver
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet multipurpose tray
- Networking
- Print server
- Printer Features
- AirStation OneTouch Secure System (AOSS)
- System Requirements
- Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Server 2008, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.6.8, Microsoft Windows Server 2012, Apple MacOS X 10.8.x
- Microsoft Certification
- Compatible with Windows 7
- 41 cm x 46.5 cm x 24 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 600 x 2400 dpi
- 600 x 2400 dpi
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 16 sec
- Printer Features
- Media Handling
RAM
- 64 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 116 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
- Networking
- Print server
- Kerberos, SSL, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK, WPS, ARP, Wi-Fi Direct
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 1000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1000 pages ISO/IEC 19798
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 335 Watt
- Power Consumption Stand by / Sleep
- 60 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- 10 °C
- 32.5 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 33 dBA
- Sound Emission (Operating)
- 53 dBA
- 41 cm
- 46.5 cm
- 24 cm
- 17.8 kg
Brother TN241BK Toner Cartridge Black | In Stock | £48.20 |
Brother TN241C Toner Cartridge Cyan | In Stock | £47.80 |
Brother TN241M Toner Cartridge Magenta | In Stock | £47.80 |
Brother TN241Y Toner Cartridge Yellow | In Stock | £47.80 |
Brother TN245C Toner Cartridge Cyan | In Stock | £67.77 |
Brother TN245M Toner Cartridge Magenta | In Stock | £67.77 |
Brother TN245Y Toner Cartridge Yellow | In Stock | £67.77 |
Brother Drum Unit yield 15k | In Stock | £72.71 |
Brother Belt Unit HL3140/MFC9140 50K | In Stock | £68.66 |
Brother Waste Toner HL3140CW/MFC9140 50K | In Stock | £13.90 |
