Brother HL-3140CW Compact Colour Laser Printer With Wi-fi
At last, a compact, high quality colour printer that is affordable to buy and affordable to run too. This is an exciting development for many small to medium sized businesses who want the impact of using colour.
This entry level printer is part of Brother's next generation colour LED printers, designed for high performance and better value. It's fast, printing 18 pages per minute, easy to use, and built for reliability, giving you the peace of mind that it won't let you down. It offers advanced and flexible connections, whether you need to print direct from USB, or web-based applications such as Apple AirPrint or Google Cloud Print.
- Save time with fast 18ppm mono/colour printing
- Flexible paper handling with 250 sheet paper capacity and single sheet bypass tray
- Faster and more secure 802.11n wireless connection or connect to your PC via high speed USB 2.0
- Effortless mobile connectivity enables printing direct from your Apple iOS, Android, Windows Phone or Blackberry device
- Lower operational costs with optional high yield colour supplies
- Print professional colour documents with output of up to 2,400 x 600dpi resolution
Compact, reliable and specially designed to suit the smaller office space. Create professional-looking colour documents and print directly from your mobile device for the ultimate convenience. Plus wireless technology means saving and sharing resources is easy.
Key Features
- Print only
- Up to 18ppm mono and colour print speed
- Up to 2,400 x 600dpi print resolution
- Wireless network ready
- Print from your mobile device
- PIN and password protected secure print
- Compact, reliable and specially designed to suit smaller office spaces
- Create professional-looking colour documents and print directly from your mobile device to the HL-3140CW for the ultimate convenience. Plus wireless technology means saving and sharing resources is easy.
- Like all of our colour LED printers, it incorporates separate toners and drums, reducing waste and saving you money. This flexible printer also offers high-yield colour toner cartridges to keep costs down without compromising on quality.
- And with print speeds of up to 18ppm, the HL-3140CW won't keep you waiting for your documents.
AirPrint
Compatible with AirPrint by Apple.
Mobile Compatible
Mobile device compatible. Connect with your smartphone or tablet.
WiFi Compatible
Wireless compatible.
Blazing fast printing
Fast color and black print speeds up to 19ppm to help improve your productivity. -
Flexible connectivity
Easy to install on your wireless network or print locally via USB from your computer. -
High-impact business printing
Produce crisp black and high-impact color business documents at up to 600 x 2400 dpi resolution using Brother's Digital LED print technology. -
Versatile paper handling
250-sheet capacity paper tray adjustable for letter or legal and a straight-through paper path via manual feed slot for envelope printing. -
Help control your color printing costs
Use the secure function lock feature to set color page counts or restrict color printing for up to 25 users. -
Help lower your operating costs
High capacity color toners available to help lower your cost per copy. -
Deep sleep mode
Deep sleep mode to conserve energy when printer is not being used.
- Brother HL-3140CW - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 17.4 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 116 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 18 ppm - B/W , Up to 18 ppm - colour
- Max Resolution (B&W)
- 2400 x 600 dpi
- Max Resolution (Colour)
- 2400 x 600 dpi
- Interface
- USB 2.0, Wi-Fi(n)
- Processor
- 333 MHz
- RAM Installed (Max)
- 64 MB
- Language Simulation
- Windows GDI driver
- Media Type
- Plain paper, bond paper, recycled paper, glossy paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 300 - 1500 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows XP Home Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows XP Professional (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 41 cm x 46.5 cm x 24 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi(n)
- 2400 x 600 dpi
- 2400 x 600 dpi
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 16 sec
- Media Handling
- Processor
- 333 MHz
RAM
- 64 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 116 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 30000 pages
- 300 - 1500 pages
- Networking
- Print server
- Kerberos, SSL, WPA-PSK, TLS, 802.1x, WPA2-PSK, ARP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages , 1 x drum
- Power Device
- Power supply - internal
- 335 Watt
- Power Consumption Stand by / Sleep
- 60 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Nordic Swan Ecolabel
- Limited warranty - 1 year
- Sound Emission (Idle)
- 33 dBA
- Sound Emission (Operating)
- 53 dBA
- 41 cm
- 46.5 cm
- 24 cm
- 17.4 kg
- Width (Shipping)
- 59.7 cm
- Depth (Shipping)
- 52.1 cm
- Height (Shipping)
- 36.4 cm
- Weight (Shipping)
- 21 kg
Brother TN241BK Toner Cartridge Black | In Stock | £48.20 |
Brother TN245C Toner Cartridge Cyan | In Stock | £67.77 |
Brother Drum Unit yield 15k | In Stock | £72.71 |
