Product
Brother HL-L8350CDW Colour Laser Multifunction Printer
Professional quality prints for less!
Quicklinx: 9JD2WS00 Mfr#: HLL8350CDWZU1
The new HL-L8350CDW will help even the smallest office increase productivity by allowing staff to create crisp, clear professional colour prints at a fraction of the price.
Improved print speeds deliver best in class performance of up to 30ppm, colour or mono, with first page out speeds of less than 10 seconds. Super-high-yield toners drive down costs and increase time between cartridge changes, while every request connects perfectly thanks to on board Wi-Fi for network sharing and Wi-Fi Direct for flawless mobile and tablet connectivity on-the-go.
  • Fast, high-quality business printing
    With print speeds up to 32 ppm in both color and black and up to 2400 x 600 dpi resolution, you no longer have to wait for high-impact business documents.
  • Easily print two-sided documents
    Using the duplex printing feature, you can help reduce your printing costs and produce professional two-sided documents, presentations and brochures.
  • Flexible connectivity
    Featuring built-in wireless 802.11 b/g/n and Ethernet network interfaces to easily setup and share on your wireless or wired network or print locally via USB from your computer.
  • Versatile paper handling
    The HL-L8350CDW offers a 250-sheet capacity paper tray that is adjustable for letter or legal size paper and a 50-sheet capacity multi-purpose tray for printing letterhead and custom paper sizes.
  • Cost-efficient printing
    Spend less time replacing supplies and help reduce operating costs by using high-yield replacement toner cartridges.
  • Help control your printing costs
    Use the secure function lock feature to set page counts or restrict printing on a per user or group basis (supports up to 100 users).
  • Walk-up printing
    Features a front-access USB direct interface to directly print from your USB flash memory drive.
  • Advanced security features
    Provides a wide-range of security features including: secure print, secure function lock, SSL, enterprise security (802.1x) and more.
Brother HL-L8350CDW - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
21.9 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm)
Max Resolution (B&W)
2400 x 600 dpi
Max Resolution (Colour)
2400 x 600 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
400 MHz
RAM Installed (Max)
128 MB (384 MB)
Language Simulation
PCL 6, XPS, BR-Script3, PDF 1.7
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper, glossy paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
60000 pages
Recommended Monthly Volume
750 - 4000 pages
Print server
AC 230V
Linux, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32-bit versions), Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008 x64 Edition, Apple MacOS X 10.7 Lion, Windows 8 64-bit Edition, Apple MacOS X 10.8, Windows 8 32-bit Edition, Microsoft Windows Server 2008 32-bit, Microsoft Windows XP 32-bit, Microsoft Windows Server 2008 R2 (64-bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Apple MacOS X 10.9, Microsoft Windows Server 2012 R2 x64 Edition, Microsoft Windows 7 32-bit Edition
Microsoft Certification
Compatible with Windows 7
41 cm x 48.6 cm x 31.3 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
2400 x 600 dpi
2400 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
10 sec
First Print Out Time Colour
10 sec
Language Simulation
Media Handling
400 MHz
RAM
RAM Installed (Max)
128 MB / 384 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
Media Weight
60 g/m² - 163 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m²
Max Media Capacity
800 sheets
Output Trays Capacity
150 sheets
Duty Cycle
60000 pages
750 - 4000 pages
Print server
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
Security Protocols & Features
Kerberos, SSL, LEAP, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, WPS
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 2500 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
AC 230V
Frequency Required
50/60 Hz
540 Watt
Power Consumption Stand by
65 Watt
Power Consumption Sleep
7.5 Watt
Software Included
Drivers & Utilities
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
27.9 dBA
Sound Emission (Operating)
53.5 dBA
Sound Emission (Quiet Mode)
50.6 dBA
41 cm
48.6 cm
31.3 cm
21.9 kg
Width (Shipping)
60 cm
Depth (Shipping)
52.4 cm
Height (Shipping)
51.3 cm
Weight (Shipping)
25.5 kg
