Open up new business opportunities with this robust machine. Offering excellent paper handling options, super fast print speeds and the new optional super-high-yield toner cartridges significantly reduces your print spend, making this machine the ideal print partner for your business.
Printer comes with free LT-5505 Tray!
Maximise Performance & Reduce Print Spend
Versatile paper handling, enables you to add multiple lower trays, and mailbox options across the range. This provides maximum device uptime, as less time is spent replenishing paper trays and searching for your printed documents. With the optional high yield toner cartridges, productivity is enhanced, whilst reducing your overall printing costs.
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L6000 range has been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Enhanced Workflow
The L6000 range introduces an intuitive and user-friendly interface, and support for multiple business cloud based services including Dropbox and Google Drive.
Tighter security
In today's business environment, we understand that organisations demand the highest levels of security. In order to address this, the L6000 range is enabled with secure function lock 3.0, 802.1x and Internet Protocol Security (IPsec). The range also boasts Print Archive, Secure Reset, Certificate Management and Near field communication (NFC) functionality for secure user access and authentication.
Flexible print solutions from Brother
Our L6000 range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions enables you to maximise your print efficiency and minimise costs, specifically tailored to your requirements.
Eco-friendly
The L6000 range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
Fast, high-quality printing for higher print volumes
Featuring a business-durable design with an impressive print speed of up to 48 pages per minute, this high-performance printer is ideal for mid-sized workgroups. Plus, it offers up to 1200 x 1200 dpi resolution for crisp, clear text and excellent graphics. -
Low total cost of ownership
Includes a high-yield 8,000-page toner cartridge for built-in value. For even lower cost printing, use the super high-yield 12,000-page replacement toner cartridge. -
Large, expandable paper capacity
Easily handle your large print jobs via an adjustable 520-sheet capacity paper tray and 50-sheet capacity multi-purpose tray. Additional optional paper trays are available in 250-sheet or 520-sheet capacities, enabling users to configure the printer with multiple trays in a way that best meets their application requirements - up to 1,610 sheet total capacity. -
Flexible network connectivity
Built-in wireless 802.11b/g/n and Gigabit Ethernet network interfaces allow you to share the HL-L6300DW with multiple users on your network. -
Print from your mobile device
Print from your mobile device via: AirPrint, Google Cloud Print 2.0, Mopria, Brother iPrint&Scan, NFC, Cortado Workplace and Wi-Fi Direct -
Automatic two-sided printing
Use the duplex feature to produce professional brochures, documents and booklets. This feature can help save money and cut your paper usage by up to 50%. -
Adjustable, 1.8" color Touchscreen display
Offers intuitive menu navigation and printing from popular business cloud services‡ including: DROPBOX, GOOGLE DRIVE, ONEDRIVE, and more -
Advanced security features
Includes an integrated NFC card reader and Active Directory support for network user authentication to help protect against unauthorized access to the device. Other security features include: Secure Function Lock, Enterprise Security (802.1x), IPSec, Secure Print, SSL/TLS and more.
- Brother HL-L6300DW - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 13.2 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 48 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 46 ppm - B/W - A4 (210 x 297 mm) , Up to 24 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 24 ppm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), NFC
- Preview Screen Size
- 1.8"
- RAM Installed (Max)
- 256 MB
- Language Simulation
- PCL 6, XPS, BR-Script3, IBM ProPrinter XL, EPSON FX-850, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper
- Total Media Capacity
- 570 sheets
- Media Handling
- 50-sheet multipurpose tray, 520-sheet input tray
- Recommended Monthly Volume
- 7500 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
- 3-year warranty
- 40 cm x 28.8 cm x 39.6 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- 1.8"
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- First Print Out Time B/W
- 7.5 sec
- Media Handling
RAM
- 256 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- Media Weight
- 60 g/m² - 200 g/m²
- 570 sheets
- Media Feeders
- 1 x automatic - 520 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m²
- Output Trays Capacity
- 260 sheets
Duty Cycle
- 7500 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP, IPPS
- Kerberos, SSL, TLS, IPsec, 802.1x, ARP, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 8000 pages , 1 x drum
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 740 Watt
- Power Consumption Stand by
- 32 Watt
- Power Consumption Sleep
- 1.6 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - replacement - 3 years
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 35 dBA
- Sound Emission (Operating)
- 54 dBA
- Sound Emission (Quiet Mode)
- 50 dBA
- 40 cm
- 28.8 cm
- 39.6 cm
- 13.2 kg
- Width (Shipping)
- 49.7 cm
- Depth (Shipping)
- 49.2 cm
- Height (Shipping)
- 42.7 cm
- Weight (Shipping)
- 15.8 kg
Ink (4)
Brother TN-3430 Black Standard Yield Toner | In Stock | £55.63 |
Brother TN-3480 Tonert 8000 Pages | In Stock | £95.57 |
Brother TN-3512 Black Super High Yield Toner | In Stock | £107.72 |
Brother HLL6400/MFCL6900DW/T Drum Unit 30K | In Stock | £112.07 |
Other bundles (1)
Brother LT6505 520 Sheet Optional Paper Tray | In Stock | £120.73 |
