Product
Brother HL-L2365DW Mono Laser Printer
Quicklinx: 9NJMWS00 Mfr#: HLL2365DWZU1
  • Windows 8 (32/64 bits)
The HL-L2365DW combines professional mono laser print with versatile connectivity options, perfect for Small Offices.
Wired and wireless network-ready, prepare to print and scan from anywhere using the Brother iPrint&Scan app, Google Cloud Print, Apple AirPrint and Wi-Fi Direct. Wherever you are in the office, professional printing is only a press of a button away.
With speeds of up to 30ppm and a 250 sheet paper tray you can focus on the tasks that matter, safe in the knowledge that your print jobs will be professionally delivered quickly and efficiently, without the need to refill the paper tray in between jobs.
Added efficiency can be found in the inbox 1200 page toner, double-sided printing feature and optional cost-effective, high-yield toner cartridges to both reduce waste and running costs.
Brother HL-L2365DW - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
6.9 kg
Media Size Class
A4
Max Media Size
215.9 x 355.6 mm
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 15 ipm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
2400 x 600 dpi
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
RAM Installed (Max)
32 MB
Language Simulation
PCL 6
Media Type
Plain paper, bond paper, recycled paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet manual tray
Recommended Monthly Volume
250 - 2000 pages
Print server
Linux, Microsoft Windows XP Home Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows XP Professional (32/64 bits), Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
Microsoft Certification
Compatible with Windows 7
35.6 cm x 36 cm x 18.3 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
2400 x 600 dpi
Brother HQ1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Language Simulation
PCL 6
Media Handling
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Media Size Class
A4
Max Media Size
215.9 x 355.6 mm
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
Media Weight
60 g/m² - 163 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m²
Output Trays Capacity
100 sheets
Duty Cycle
250 - 2000 pages
Print server
Security Protocols & Features
WEP, WPA-PSK
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) , 1 x drum - up to 12000 pages - Brother DR-2300
Environmental Standards
Blue Angel
ENERGY STAR
Nordic Swan Ecolabel
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
50 dBA
Sound Emission (Quiet Mode)
45 dBA
35.6 cm
36 cm
18.3 cm
6.9 kg
Width (Shipping)
44.1 cm
Depth (Shipping)
28.6 cm
Height (Shipping)
50.4 cm
Weight (Shipping)
8 kg
