A perfect Mono Laser printer for connected Small Offices. Print high-quality documents in black and white with the touch of a button with this tablet and Wi-Fi enabled, mobile print compatible machine.
With print speeds of up to 26ppm your documents can be ready before you arrive at the printer to pick them up. The 250 sheet paper tray allows you to spend more time creating your documents instead of reloading an empty paper tray to print them.
Also prepare to print from anywhere, using the Brother iPrint&Scan app, Google Cloud Print, Apple AirPrint and Wi-Fi Direct you can send your documents to print using your tablet or mobile device.
With efficiency in mind, the double-sided printing feature and optional, high-yield toner cartridges you can expect reduced waste and costs.
Flexible connectivity
Provides built-in wireless 802.11 b/g/n, and Wi Fi Direct to share with others on your network. Eliminate extra cables and conveniently place your printer with wireless networking or connect locally to a single user via its High-Speed USB 2.0 interface. -
Easily print two-sided documents
Produce professional two-sided documents, brochures and booklets using the automatic duplex printing feature. This feature can reduce your paper use and help save money. -
Convenient paper handling
The HL-L2340DW can meet all of your printing needs via an adjustable, 250-sheet capacity paper tray‡ that handles letter or legal size paper and a manual feed slot for printing envelopes and letterhead. -
Straight-through paper path
A manual feed slot and rear paper exit provide a straight-through paper path to ensure that all of your printed materials always look their best. -
Fast, high-quality output
Helps improve your productivity with a print speed of up to 27 ppm and produces crisp text and excellent graphics at up to 2400 x 600 dpi. -
Toner save mode
Use less toner and save money by using Toner Save mode for your less critical business documents.
- Brother HL-L2340DW - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 6.9 kg
- Media Size Class
- A4
- Max Media Size
- 215.9 x 355.6 mm
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 26 ppm - B/W - A4 (210 x 297 mm) , Up to 13 spm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Image Enhancement Technology
- Brother HQ1200
- Automatic Duplexing
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- RAM Installed (Max)
- 32 MB
- Language Simulation
- Windows GDI driver
- Media Type
- Plain paper, bond paper, recycled paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet manual tray
- Recommended Monthly Volume
- 250 - 2000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows XP Home Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows XP Professional (32/64 bits), Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
- Microsoft Certification
- Compatible with Windows 7
- 35.6 cm x 36 cm x 18.3 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- 2400 x 600 dpi
- Brother HQ1200
- First Print Out Time B/W
- 8.5 sec
- Media Handling
RAM
- 32 MB
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- 215.9 x 355.6 mm
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 250 - 2000 pages
- Networking
- Print server
- WEP, WPA-PSK
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages , 1 x drum - up to 12000 pages - Brother DR2300
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Nordic Swan Ecolabel
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 49 dBA
- Sound Emission (Quiet Mode)
- 45 dBA
- 35.6 cm
- 36 cm
- 18.3 cm
- 6.9 kg
- Width (Shipping)
- 44.1 cm
- Depth (Shipping)
- 28.6 cm
- Height (Shipping)
- 50.4 cm
- Weight (Shipping)
- 8 kg
