The HL-5440D has been specially designed to handle high pressure workloads in a busy office as a matter of routine.
Offering professional 1,200dpi resolution, its output runs up to 38ppm, with the first page out in under 8.5 seconds. The standard paper capacity is an impressive 300 sheets, and you can easily add more if required.
And with the option of an 8,000-page high-yield toner cartridge, plus automatic duplex printing with booklet capability, the HL-5440D does more, faster – and for less.
Secure
Be in control with secure local connectivity. The HL-5440D offers both Windows and Mac compatibility. Its secure USB interface provides full speed connectivity for most modern business devices. -
Cost effective
A range of cost saving features including toner save mode and booklet printing allow significant reductions on print costs. The optional 8,0001 page high yield toner cartridge together with the separate drum unit means you can be sure of exceedingly low running costs. -
Professional
Thanks to the 1,200 x 1,200dpi print resolution you'll get sharp crisp text and accurate reproduction of even the finest details on the page. With automatic 2-sided and booklet printing as standard, you can produce professional reports and presentations and reduce paper consumption by up to 75%. -
Compact
With office space at a premium the HL-5440D is designed to fit in, with its compact size and stylish design making it work in even the smallest of spaces. -
Productive
A first page out time of less than 8.5 seconds and an impressive print speed of up to 38ppm ensures large volume print jobs are handled with ease and deadlines are met.
- Brother HL-5440D - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- 10.4 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 38 ppm - B/W , Up to 18 ppm - B/W duplex
- Max Resolution (B&W)
- 2400 x 600 dpi
- Image Enhancement Technology
- Brother HQ1200
- Automatic Duplexing
- Interface
- Parallel, USB
- Processor
- 400 MHz
- RAM Installed (Max)
- 64 MB
- Language Simulation
- PCL 6, BR-Script3, IBM ProPrinter XL, EPSON FX-850
- Barcodes
- Code 39, UCC/EAN-128, ISBN, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Interleaved 2 of 5, Postnet, FIM, Code 128B, Code 128C, Code 128A
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 500 - 3000 pages
- System Requirements
- Linux, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Apple MacOS X 10.5.8, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- 37.1 cm x 38.4 cm x 24.5 cm
- Printer Type
- Personal printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- 2400 x 600 dpi
- Brother HQ1200
- PostScript Support
- Standard
- First Print Out Time B/W
- 8.5 sec
- Fonts Included
- 66 x scalable PCL , 66 x scalable PostScript , 12 x bitmapped PCL
- Barcodes
- Media Handling
- Processor
- 400 MHz
RAM
- 64 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
- Media Weight
- 60 g/m² - 163 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 800 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 50000 pages
- 500 - 3000 pages
- Expansion Slots
- Memory
- Connections
- 1 x USB 2.0 , 1 x parallel - 36 PIN Centronics
- Consumables Included
- 1 x toner cartridge (black) - up to 2000 pages ISO/IEC 19752 , 1 x drum - up to 25000 pages
- Power Device
- Power supply - internal
- 700 Watt
- Power Consumption Stand by / Sleep
- 4.8 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 2 years - carry-in , Limited warranty - 1 year - on-site
- Sound Emission (Idle)
- 34 dBA
- Sound Emission (Operating)
- 59 dBA
- Sound Emission (Quiet Mode)
- 54 dBA
- 37.1 cm
- 38.4 cm
- 24.5 cm
- 10.4 kg
- Width (Shipping)
- 49.9 cm
- Depth (Shipping)
- 47.8 cm
- Height (Shipping)
- 38 cm
- Weight (Shipping)
- 12.4 kg
Brother DR-3300 Drum Unit | In Stock | £123.26 |
Brother TN3330 Toner Cartridge - Black | In Stock | £57.13 |
Brother TN3380 Black Toner Cartridge | In Stock | £90.03 |
