Brother HL-1210W Mono Laser Printer
Quicklinx: 9X78WS00 Mfr#: HL1210WZU1
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
The Brother HL-1210W is stylishly designed and compact enough to fit onto a shelf or workstation. It produces outputs with the speed and quality you would expect from a more expensive machine.
Installation is very easy – connect using wireless or the USB cable, and you will be printing in no time. Plus innovative Anti-Jam technology allows you to print wirelessly with no hassle. You will also be able to print at speeds of up to 20 pages per minute (ppm), and your first page will come out in less than 10 seconds.
Brother HL-1210W - printer - monochrome - laser
Printer Type
Workgroup printer - laser - monochrome
4.6 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
148 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 20 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
2400 x 600 dpi
Image Enhancement Technology
Brother HQ1200
USB 2.0, Wi-Fi(n)
RAM Installed (Max)
32 MB
Language Simulation
Windows GDI driver
Media Type
Plain paper, recycled paper
Total Media Capacity
150 sheets
Media Handling
150-sheet input tray
Recommended Monthly Volume
250 - 1800 pages
AC 230V
Linux, Android, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7 Lion, Apple iOS, Windows 8 (32/64 bits), Apple MacOS X 10.8, Microsoft Windows Server 2008 32-bit, Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Microsoft Windows Server 2008 (64-bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Windows Phone
34 cm x 23.8 cm x 18.9 cm
Printer Type
Printer
Print Speed
Wireless
USB 2.0, Wi-Fi(n)
2400 x 600 dpi
Brother HQ1200
First Print Out Time B/W
10 sec
Language Simulation
Windows GDI driver
Media Handling
RAM
RAM Installed (Max)
32 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
148 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm), 216 x 355.6 mm, 148 x 148 mm
Media Weight
65 g/m² - 105 g/m²
150 sheets
Media Feeders
1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 65 g/m² - 105 g/m²
Output Trays Capacity
50 sheets
Duty Cycle
250 - 1800 pages
Remote Management Protocol
TFTP
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, TKIP, AES
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 700 pages
Power supply
AC 230V
380 Watt
Power Consumption Stand by
40 Watt
Power Consumption Sleep
0.7 Watt
Environmental Standards
Blue Angel
ENERGY STAR
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
51 dBA
34 cm
23.8 cm
18.9 cm
4.6 kg
Width (Shipping)
41.5 cm
Depth (Shipping)
30.3 cm
Height (Shipping)
32.4 cm
Weight (Shipping)
5.5 kg
