Your basket is empty
Brother FAX-T106 fax machine
Quicklinx: 3VBCWS00 Mfr#: FAXT106U1
When you need to connect and share information fast and effectively, the FAX-T106 performs on all fronts.
Easy to set up and simple to use, the FAX-T106 has a 25-sheet memory back up as well as 104 quick dial locations, while crisp prints guarantee a professional finish every time.
And with its high speeds, integrated handset and built-in answering machine, this stylish thermal transfer fax machine not only helps you to communicate more clearly and quickly, but also looks great too.
Brother FAX-T106 - fax / copier (B/W)
Fax / copier
Fax Type
G3 - plain paper
Printing Technology
Thermal transfer (monochrome)
Max Fax Transmission Speed
14.4 Kbps
Answering Machine
(up to 15 min)
Original Size
148 mm width (min) - 216 mm width (max)
Original Type
Sheets
Document Feeder Capacity
10 sheets
Media Type
Plain paper
Standard Media Capacity
30 sheets
Office Machine Features
Answering machine
AC 230 V (50/60Hz)
30.2 cm x 26.7 cm x 34 cm
2.8 kg
1 year warranty
Fax / copier
Fax Type
Plain paper
Printing Technology
Thermal transfer - monochrome
Display
1 line x 16 characters
Answering machine
Standard Memory
512 KB
Copying
Max Document Enlargement
150%
Max Document Reduction
50%
Preset Enlargements
150%, 120%, 125%
Preset Reductions
50%, 93%, 87%, 75%
Maximum Copies
99
Fax Machine
Compatibility
G3
Max Transmission Speed
14.4 Kbps
Handset
Corded handset
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
4 station(s)
Speed Dialing
100 station(s)
Broadcast Transmission
104 stations
Answering Machine
Recording Capacity
Up to 15 min
Document & Media Handling
Min Original Size
148 mm width
Max Original Size
216 mm width
Original Type
Sheets
10 sheets
Min Media Weight
64 g/m²
Max Media Weight
90 g/m²
Supported Media Type
Plain paper
30 sheets
Paper cassette - 30 sheets - A4 (210 x 297 mm) , ADF - 10 sheets size: 148 mm width - 216 mm width
AC 230 V (50/60Hz)
160 Watt
Power Consumption Standby
4.8 Watt
Limited warranty - 1 year - on-site
30.2 cm
26.7 cm
34 cm
2.8 kg
3VBC Brother Re-Fill for Fax T-74/76/78 In Stock £10.19
3VBC Brother PC-72RF 2 Ribbon Refill In Stock £18.06
3VBC Brother T104/T106 FAX CART INC 144 SHT RIBB In Stock £14.84
