The FAX-T104 has been specifically designed to fit perfectly in any home.
Easy to use and simple to install, this versatile machine combines sharpness and quality with a whole host of fax management features – helping to make your communications more efficient.
With a 25-sheet memory back up and 104 quick dial locations, the FAX-T104 enables you to connect and share information quickly. The clear print quality adds that all-important touch of professionalism, while the adjustable volume makes sending and receiving faxes less of a headache.
- Brother FAX-T104 - fax / copier - B/W
- Fax / copier
- Fax Type
- G3 - plain paper
- Printing Technology
- Thermal transfer (monochrome)
- Max Fax Transmission Speed
- 9.6 Kbps
- Original Size
- 148 mm width (min) - 216 mm width (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 10 sheets
- Media Type
- Plain paper
- Standard Media Capacity
- 30 sheets
- Power
- AC 230 V (50/60Hz)
- 30.2 cm x 26.7 cm x 34 cm
- 2.7 kg
- 1-year warranty
- Fax / copier
- Fax Type
- Plain paper
- Thermal transfer - monochrome
- Display
- 1 line x 16 characters
- Standard Memory
- 512 KB 512 KB
Copying
- Max Document Enlargement
- 150%
- Max Document Reduction
- 50%
- Preset Enlargements
- 150%, 120%, 125%
- Preset Reductions
- 50%, 93%, 87%, 75%
- Maximum Copies
- 99
Fax Machine
- Compatibility
- G3
- Max Transmission Speed
- 9.6 Kbps
- Handset
- Corded handset
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 4 station(s)
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 104 stations
Document & Media Handling
- Min Original Size
- 148 mm width
- Max Original Size
- 216 mm width
- Original Type
- Sheets
- 10 sheets
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 90 g/m²
- Supported Media Type
- Plain paper
- 30 sheets
- Paper cassette - 30 sheets - A4 (210 x 297 mm) , ADF - 10 sheets size: 148 mm width - 216 mm width
- Voltage Required
- 160 Watt
- Power Consumption Standby
- 4.4 Watt
- Limited warranty - 1 year - on-site
- 30.2 cm
- 26.7 cm
- 34 cm
- 2.7 kg
Brother T104/T106 FAX CART INC 144 SHT RIBB | In Stock | £16.19 |
