Brother FAX-2940 High Speed Mono Laser Multifunction Printer
Quicklinx: 87GQWS00 Mfr#: FAX2940ZU1
Functionality: Copier, Fax, Printer, Scanner
Output Type: Monochrome
Wireless Capability: [N/A]
Technology: Laser
Hurry, only 3 left in stock!
£228.65 ex VAT
£274.38 inc VAT
With a free printer and scanner download available, you can turn the high speed FAX-2940 into a multifunction machine you can depend on.
Easy to set up and operate, it boasts a host of features and technology to help you work smarter. The 250-sheet lower paper tray adds up to less time wasted refilling, while the huge 500-page memory means that, even if your paper does run out, your vital information won't be lost.
The high-yield toner can handle the unit's fast printing speeds – up to 20ppm – while the separate drum keeps running costs low.
All in all a flexible solution offering everything your office needs to operate more efficiently.
  • Separate toner and drum
    Less wastage and reduced print costs.
  • Toner save
    The eco feature uses less toner, which can help you to reduce your print spend.
  • N-in-1
    Reduce paper consumption by up to 75% by copying multiple pages onto a single sheet of paper.
  • Sleep mode
    Consumes only 1.5 W of power when not in use, which is over 36 times less energy than in the standard ready mode.
Brother FAX-2940 - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 1200 x 1200 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 600 dpi
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Type
Plain paper
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB
36.8 cm x 36 cm x 31.1 cm
9 kg
Microsoft Certification
Compatible with Windows 7
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - monochrome
USB
Copying
Max Copying Speed
Up to 20 ppm
Maximum Copies
99
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Image Enhancement Technology
Brother HQ1200
First Print Out Time B/W
10 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Reception Memory Capacity
Up to 500 pages
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
22 station(s)
Speed Dialing
200 station(s)
Document & Media Handling
Original Type
Sheets
30 sheets
Supported Media Type
Plain paper
250 sheets
100 sheets
ADF - 30 sheets , Input tray - 250 sheets , Output tray - 100 sheets
Speed Details
Copying: up to 20 ppm - B/W , Printing: up to 20 ppm - B/W
1 x USB
360 Watt
Power Consumption Standby
53 Watt
Power Consumption Sleep
1.5 Watt
Consumables Included
1 x Cartridge (black) - up to 1000 pages , 1 x drum - up to 12000 pages - Brother DR-2200
Limited warranty - 1 year
36.8 cm
36 cm
31.1 cm
9 kg
Shipping Width
47.6 cm
Shipping Depth
45.8 cm
Shipping Height
43.6 cm
Shipping Weight
12.9 kg
87GQ Brother TN2220 - Toner cartridge - 1 - 2600 pages In Stock £46.71
87GQ Brother BRO DR2200 DRUM HL2240/2240D/ In Stock £53.04
87GQ Brother TN2210 - Toner cartridge - 1 - 1200 pages In Stock £30.22
Functionality: Fax
Functionality: Printer
Functionality: Scanner
Technology: Laser
Max Print Speed: [N/A]
Brand: Brother
Price Range Ex VAT: 150 - 300
