With a free printer and scanner download available, you can turn the high speed FAX-2940 into a multifunction machine you can depend on.
Easy to set up and operate, it boasts a host of features and technology to help you work smarter. The 250-sheet lower paper tray adds up to less time wasted refilling, while the huge 500-page memory means that, even if your paper does run out, your vital information won't be lost.
The high-yield toner can handle the unit's fast printing speeds – up to 20ppm – while the separate drum keeps running costs low.
All in all a flexible solution offering everything your office needs to operate more efficiently.
Separate toner and drum
Less wastage and reduced print costs. -
Toner save
The eco feature uses less toner, which can help you to reduce your print spend. -
N-in-1
Reduce paper consumption by up to 75% by copying multiple pages onto a single sheet of paper. -
Sleep mode
Consumes only 1.5 W of power when not in use, which is over 36 times less energy than in the standard ready mode.
- Brother FAX-2940 - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 1200 x 1200 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Up to 600 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 600 dpi
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Type
- Plain paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB
- 36.8 cm x 36 cm x 31.1 cm
- 9 kg
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- Fax Type
- Plain paper
- Laser - monochrome
- Interface
- USB
Copying
- Max Copying Speed
- Up to 20 ppm
- Maximum Copies
- 99
Printing
- Up to 20 ppm
- Image Enhancement Technology
- Brother HQ1200
- First Print Out Time B/W
- 10 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Reception Memory Capacity
- Up to 500 pages
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 22 station(s)
- Speed Dialing
- 200 station(s)
Document & Media Handling
- Original Type
- Sheets
- 30 sheets
- Supported Media Type
- Plain paper
- 250 sheets
- 100 sheets
- ADF - 30 sheets , Input tray - 250 sheets , Output tray - 100 sheets
- Speed Details
- Copying: up to 20 ppm - B/W , Printing: up to 20 ppm - B/W
- 1 x USB
- 360 Watt
- Power Consumption Standby
- 53 Watt
- Power Consumption Sleep
- 1.5 Watt
- Consumables Included
- 1 x Cartridge (black) - up to 1000 pages , 1 x drum - up to 12000 pages - Brother DR-2200
- Limited warranty - 1 year
- 36.8 cm
- 36 cm
- 31.1 cm
- 9 kg
- Shipping Width
- 47.6 cm
- Shipping Depth
- 45.8 cm
- Shipping Height
- 43.6 cm
- Shipping Weight
- 12.9 kg
Brother TN2220 - Toner cartridge - 1 - 2600 pages | In Stock | £47.53 |
Brother BRO DR2200 DRUM HL2240/2240D/ | In Stock | £53.97 |
Brother TN2210 - Toner cartridge - 1 - 1200 pages | In Stock | £30.76 |
