This compact A4 inkjet all-in-one printer provides the same professional standards you would expect in the office, with a design that will fit right in at home. It's built for work, offering fast quality printing, scanning and copying all-in-one machine. Many time and cost-saving features come as standard, such as automatic double-sided printing. Wireless network-ready out of the box means you can share the features with the whole family, and with its impressive photo quality and 20 sheet photo tray, the family might want to use it too! And having the option for low and high yield toner cartridges, and lower power consumption you can keep running costs to a minimum.
- Brother DCP-J725DW - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Max Copying Speed
- Up to 23 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Printing Speed
- Up to 12 ppm (mono) / up to 10 ppm (colour)
- Max Printing Resolution
- Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 20 sheets
- Media Size
- ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Transparencies, plain paper
- Standard Media Capacity
- 100 sheets
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n), USB host
- Office Machine Features
- Print from memory card, print from USB flash drive, scan to e-mail, scan to network
- 40.5 cm x 37.8 cm x 18 cm
- 9 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Copier Type
- Digital
- Ink-jet - colour
- Display Features
- Touch screen
- Interface
- Standard Memory
- 64 MB 64 MB
- Supported Flash Memory
- Memory Stick, SD Memory Card, MultiMediaCard, Memory Stick PRO, USB flash drive, MultiMediaCardplus, SDHC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Copying Features
- 2 on 1, 4 on 1
Printing
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
Scanning
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth (Internal)
- 36-bit
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- 20 sheets
- Max Media Size
- Ledger
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 102 x 152 mm, 100 x 148 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 127 x 178 mm
- Borderless Photo Sizes
- A4 (210 x 297 mm)
- 100 sheets
- 50 sheets
- Input tray - 100 sheets - Ledger (279 x 432 mm) , Output tray - 50 sheets , ADF - 20 sheets
- Speed Details
- Printing: up to 35 ppm - B/W draft , Printing: up to 27 ppm - colour draft , Copying: up to 23 ppm - B/W , Copying: up to 20 ppm - colour , Printing: 15 sec (10 x 15 cm (4"x6")) , Printing: up to 12 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - colour (ISO/IEC 24734)
- 1 x USB 2.0 , 1 x USB host
- LEAP, WPA-PSK, WPA2-PSK, TKIP, AES
- Operating System Support
- MS Windows XP, MS Windows 2000, Linux, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.4.11, MS Windows Vista, Apple Mac OS X 10.5.x
- Software Included
- Reallusion FaceFilter Studio, Presto! PageManager 9
- Direct Printing Specifications
- PictBridge
- Included Accessories
- Brother Paper Pack
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 40.5 cm
- 37.8 cm
- 18 cm
- 9 kg
- Shipping Width
- 46.5 cm
- Shipping Depth
- 25.5 cm
- Shipping Height
- 46 cm
- Shipping Weight
- 11.6 kg
- Sound Emission
- 50 dBA (operating)
Brother LC1240BK - Print cartridge - 1 x black - 600 pages | In Stock | £17.46 |
Brother LC1240M - Print cartridge - 1 x magenta - 600 pages | In Stock | £11.17 |
Brother LC1240Y - Print cartridge - 1 x yellow - 600 pages | In Stock | £14.00 |
