Ideal for the small to medium office, the DCP-L8450CDW not only has a best-in-class print speed of 30ppm (colour or mono), it's also more economical than most thanks to optional super-high-yield toners and automatic 2-sided print to cut down waste.
Staying in step with 'Bring Your Own Device' (BYOD) thinking, the smart connectivity of the DCP-L8450CDW enables seamless scanning and printing with tablets and mobile devices using Wi-fi Direct. While cloud services are easily accessed for printing, digitising and sharing via the easy-to-use 9.3cm touchscreen LCD.
- Brother DCP-L8450CDW - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 60000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Max Copying Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Printing Speed
- Up to 30 ppm (mono) / up to 30 ppm (colour)
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 4.85"
- Original Size
- 215.9 x 355.6 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 800 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, AOSS
- Power
- AC 230 V (50/60Hz)
- 49 cm x 52.6 cm x 53 cm
- 30.2 kg
- Microsoft Certification
- Compatible with Windows 7
- Laser - colour
- 60000 pages
- 750 - 4000 pages
- Display Diagonal Size
- 4.85"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 256 MB
- Max Supported Memory
- 512 MB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 15 sec
Scanning
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- 215.9 x 355.6 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
- 300 sheets
- 800 sheets
- 50 sheets
- 150 sheets
- ADF - 50 sheets size: 147.3 x 147.3 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- SSL, WEP, WPA-PSK, TLS, WPA, IPsec, 802.1x, WPA2-PSK, TKIP, AES, Wi-Fi Direct, TTLS
- Operating System Support
- MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.7.5, MS Windows Server 2012 R2 x64 Edition, Apple Mac OS X 10.9.x
- Voltage Required
- 565 Watt
- Power Consumption Standby
- 65 Watt
- Power Consumption Sleep
- 9.5 Watt
- First Copy Out Time B/W
- 18 sec
- First Copy Out Time Colour
- 20 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 2500 pages - Brother TN321BK , 1 x toner cartridge (cyan) - up to 1500 pages - Brother TN321C , 1 x toner cartridge (magenta) - up to 1500 pages - Brother TN321M , 1 x toner cartridge (yellow) - up to 1500 pages - Brother TN321Y
- "Compatible with Windows 7" software and devices carry Microsoftâs assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7.
- 49 cm
- 52.6 cm
- 53 cm
- 30.2 kg
- Shipping Width
- 66 cm
- Shipping Depth
- 62.5 cm
- Shipping Height
- 69.8 cm
- Shipping Weight
- 35.2 kg
- Sound Emission
- 28 dBA (idle) / 56 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
