Brother DCP-L8450CDW Colour Laser Multifunction Printer
IDEAL FOR THE SMALL TO MEDIUM OFFICE
Quicklinx: 9JD7WS00 Mfr#: DCPL8450CDWZU1
Ideal for the small to medium office, the DCP-L8450CDW not only has a best-in-class print speed of 30ppm (colour or mono), it's also more economical than most thanks to optional super-high-yield toners and automatic 2-sided print to cut down waste.
Staying in step with 'Bring Your Own Device' (BYOD) thinking, the smart connectivity of the DCP-L8450CDW enables seamless scanning and printing with tablets and mobile devices using Wi-fi Direct. While cloud services are easily accessed for printing, digitising and sharing via the easy-to-use 9.3cm touchscreen LCD.
Brother DCP-L8450CDW - multifunction printer - colour
Multifunction printer
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
60000 pages
Recommended Monthly Volume
750 - 4000 pages
Max Copying Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Max Printing Speed
Up to 30 ppm (mono) / up to 30 ppm (colour)
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Scanning
1200 x 2400 dpi
Display
4.85"
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
Standard Media Capacity
300 sheets
Max Media Capacity
800 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, AOSS
AC 230 V (50/60Hz)
49 cm x 52.6 cm x 53 cm
30.2 kg
Microsoft Certification
Compatible with Windows 7
Printing Technology
Laser - colour
60000 pages
750 - 4000 pages
Display Diagonal Size
4.85"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
512 MB
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3
Automatic Duplexing
First Print Out Time B/W
15 sec
First Print Out Time Colour
15 sec
Scanning
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
300 sheets
Max Media Capacity
800 sheets
50 sheets
150 sheets
ADF - 50 sheets size: 147.3 x 147.3 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 30 ppm (A4) - colour , Printing: up to 14 spm (A4) - B/W duplex , Printing: up to 14 spm (A4) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
SSL, WEP, WPA-PSK, TLS, WPA, IPsec, 802.1x, WPA2-PSK, TKIP, AES, Wi-Fi Direct, TTLS
Operating System Support
MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.7.5, MS Windows Server 2012 R2 x64 Edition, Apple Mac OS X 10.9.x
AC 230 V (50/60Hz)
565 Watt
Power Consumption Standby
65 Watt
Power Consumption Sleep
9.5 Watt
First Copy Out Time B/W
18 sec
First Copy Out Time Colour
20 sec
Consumables Included
1 x toner cartridge (black) - up to 2500 pages - Brother TN321BK , 1 x toner cartridge (cyan) - up to 1500 pages - Brother TN321C , 1 x toner cartridge (magenta) - up to 1500 pages - Brother TN321M , 1 x toner cartridge (yellow) - up to 1500 pages - Brother TN321Y
49 cm
52.6 cm
53 cm
30.2 kg
Shipping Width
66 cm
Shipping Depth
62.5 cm
Shipping Height
69.8 cm
Shipping Weight
35.2 kg
Sound Emission
28 dBA (idle) / 56 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
