Brother DCP-J562DW Compact Inkjet AIO with Touch screen LCD
HIGH QUALITY PRINTS AT HOME!
Quicklinx: BXC3WS00 Mfr#: DCPJ562DWZU1
It’s time to take high-quality colour printing home. Print, scan and copy in high-quality colour with this compact all-in-one home printer. Fast print speeds ensure there’s no waiting around for your photos, homework or any other home printing needs.
The 6.8cm LCD touch panel display makes menu selection simple and navigation easy, allowing you to access cloud and mobile connectivity apps at the touch of a button. Scan photos and documents direct to cloud services including Facebook, OneDrive, Google Drive and Dropbox. You can also print directly from your smartphone or tablet device via Apple AirPrint, Google Cloud Print or Brother’s Free iPrint&Scan app.
With built-in wireless networking, the DCP-J562DW can integrate seamlessly into your home. Print and scan to your printer from anywhere in the house and pick up your documents when it’s convenient.
Home printing can be a versatile task but with the single sheet rear manual feed slot and integrated 20 sheet photo paper tray, you can print a variety of different document types without needing to change the paper in the tray.
And you needn’t spend a fortune to ensure that you can keep printing with our high-yield supplies. Our lowest ever replacement ink prices, combined with 2-sided print and ink save mode, help lower operating costs to ensure you get great value for money.
  • Increase your productivity with advanced editing tools
    In addition to printing and scanning from your mobile devices using Brother iPrint&Scan, the enhanced features allow you to preview your jobs and edit if necessary. You can also scale, straighten and crop images or documents through your mobile devices before sending to print.
  • Make life simpler through wireless printing
    Now, you no longer need to connect your devices to a router for every single print job. With Wi-Fi Direct, you can conveniently print and scan by simply connecting directly to the Brother Inkjet Multi-Function Center Series.
  • Easy scan to email
    Scan and share hard-copy documents anywhere in the world directly from the Brother Inkjet via e-mail and selected cloud storage sites. It's a quick and easy way to distribute information without needing a computer or worrying about scanner drivers or e-mail settings.
  • Scan to office
    You can now save time by eliminating the need to recreate documents from scratch. With Brother Inkjets, you can scan a document and directly convert the image into an editable Word, Excel or Powerpoint file that you can save, change and use again.
  • WebConnect
    Print photos and documents directly without using your computer. WebConnect enables you to upload photos and documents to popular online services such as Dropbox, Facebook, Flickr, Google Drive and many more so you can print them anytime. It's that easy.
Brother DCP-J562DW - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Max Copying Speed
Up to 5.6 ppm (mono) / up to 2.7 ppm (colour)
Max Copying Resolution
Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
Max Printing Speed
Up to 12 ppm (mono) / up to 6 ppm (colour)
Max Printing Resolution
Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Display
2.7"
Original Size
215.9 x 297 mm (max)
Original Type
Sheets
Media Size
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper, coated paper, glossy paper
Standard Media Capacity
120 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
50 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, AOSS, scan to memory card
AC 230 V (50/60Hz)
40 cm x 34.1 cm x 15.1 cm
7.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Printing Technology
Ink-jet - colour
Display Diagonal Size
2.7"
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Standard Memory
128 MB
Supported Flash Memory
SD Memory Card, MultiMediaCard, Memory Stick Duo, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy
Printing
Nozzle Configuration
210 nozzles (black), 3 x 70 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Ink Type
Brother Innobella ink
Automatic Duplexing
Scanning
Automatic Duplexing
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Document & Media Handling
Max Original Size
215.9 x 297 mm
Original Type
Sheets
Max Media Size
A4/Letter
Min Media Weight
64 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 127 x 203 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
120 sheets
1 sheet
50 sheets
Input tray - 100 sheets , Photo tray - 20 sheets , Output tray - 50 sheets
Speed Details
Printing: up to 12 ipm - B/W , Printing: up to 6 ipm - colour , Copying: up to 5.6 ipm - B/W , Copying: up to 2.7 ipm - colour
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, AES, ARP
Operating System Support
MS Windows XP Professional x64 Edition, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.7.5, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
Software Included
Brother ControlCentre2, Brother ControlCenter4, Nuance PaperPort 14 SE with OCR
AC 230 V (50/60Hz)
19 Watt
Power Consumption Standby
3 Watt
Power Consumption Sleep
0.8 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
ENERGY STAR Certified
Blue Angel Compliant
40 cm
34.1 cm
15.1 cm
7.2 kg
Shipping Width
47.7 cm
Shipping Depth
22.8 cm
Shipping Height
45.7 cm
Shipping Weight
8.8 kg
Sound Emission
50 dBA (operating)
10 °C
35 °C
20 - 80% (non-condensing)
