It’s time to take high-quality colour printing home. Print, scan and copy in high-quality colour with this compact all-in-one home printer. Fast print speeds ensure there’s no waiting around for your photos, homework or any other home printing needs.
The 6.8cm LCD touch panel display makes menu selection simple and navigation easy, allowing you to access cloud and mobile connectivity apps at the touch of a button. Scan photos and documents direct to cloud services including Facebook, OneDrive, Google Drive and Dropbox. You can also print directly from your smartphone or tablet device via Apple AirPrint, Google Cloud Print or Brother’s Free iPrint&Scan app.
With built-in wireless networking, the DCP-J562DW can integrate seamlessly into your home. Print and scan to your printer from anywhere in the house and pick up your documents when it’s convenient.
Home printing can be a versatile task but with the single sheet rear manual feed slot and integrated 20 sheet photo paper tray, you can print a variety of different document types without needing to change the paper in the tray.
And you needn’t spend a fortune to ensure that you can keep printing with our high-yield supplies. Our lowest ever replacement ink prices, combined with 2-sided print and ink save mode, help lower operating costs to ensure you get great value for money.
Increase your productivity with advanced editing tools
In addition to printing and scanning from your mobile devices using Brother iPrint&Scan, the enhanced features allow you to preview your jobs and edit if necessary. You can also scale, straighten and crop images or documents through your mobile devices before sending to print. -
Make life simpler through wireless printing
Now, you no longer need to connect your devices to a router for every single print job. With Wi-Fi Direct, you can conveniently print and scan by simply connecting directly to the Brother Inkjet Multi-Function Center Series. -
Easy scan to email
Scan and share hard-copy documents anywhere in the world directly from the Brother Inkjet via e-mail and selected cloud storage sites. It's a quick and easy way to distribute information without needing a computer or worrying about scanner drivers or e-mail settings. -
Scan to office
You can now save time by eliminating the need to recreate documents from scratch. With Brother Inkjets, you can scan a document and directly convert the image into an editable Word, Excel or Powerpoint file that you can save, change and use again. -
WebConnect
Print photos and documents directly without using your computer. WebConnect enables you to upload photos and documents to popular online services such as Dropbox, Facebook, Flickr, Google Drive and many more so you can print them anytime. It's that easy.
- Brother DCP-J562DW - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Max Copying Speed
- Up to 5.6 ppm (mono) / up to 2.7 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
- Max Printing Speed
- Up to 12 ppm (mono) / up to 6 ppm (colour)
- Max Printing Resolution
- Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 2.7"
- Original Size
- 215.9 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, recycled paper, coated paper, glossy paper
- Standard Media Capacity
- 120 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card, AOSS, scan to memory card
- Power
- AC 230 V (50/60Hz)
- 40 cm x 34.1 cm x 15.1 cm
- 7.2 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Ink-jet - colour
- Display Diagonal Size
- 2.7"
- Display Features
- Touch screen
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Standard Memory
- 128 MB
- Supported Flash Memory
- SD Memory Card, MultiMediaCard, Memory Stick Duo, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy
Printing
- Nozzle Configuration
- 210 nozzles (black), 3 x 70 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Ink Type
- Brother Innobella ink
Scanning
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
Document & Media Handling
- Max Original Size
- 215.9 x 297 mm
- Original Type
- Sheets
- Max Media Size
- A4/Letter
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 127 x 203 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 120 sheets
- 1 sheet
- 50 sheets
- Input tray - 100 sheets , Photo tray - 20 sheets , Output tray - 50 sheets
- Speed Details
- Printing: up to 12 ipm - B/W , Printing: up to 6 ipm - colour , Copying: up to 5.6 ipm - B/W , Copying: up to 2.7 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B
- WEP, WPA-PSK, WPA2-PSK, AES, ARP
- Operating System Support
- MS Windows XP Professional x64 Edition, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.7.5, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
- Software Included
- Brother ControlCentre2, Brother ControlCenter4, Nuance PaperPort 14 SE with OCR
- Voltage Required
- 19 Watt
- Power Consumption Standby
- 3 Watt
- Power Consumption Sleep
- 0.8 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- Blue Angel Compliant
- 40 cm
- 34.1 cm
- 15.1 cm
- 7.2 kg
- Shipping Width
- 47.7 cm
- Shipping Depth
- 22.8 cm
- Shipping Height
- 45.7 cm
- Shipping Weight
- 8.8 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
