A PERFECT FIT FOR YOUR HOME OR SMALL OFFICE BUSINESS
Our latest 3-in-1 A4 inkjet with A3 capability
It's easy to connect to the DCP-J4120DW from your PC, laptop or mobile device thanks to its integrated wireless networking, allowing any users in your office or home to print and scan with ease.
The 6.8cm colour touchscreen lets you connect to popular cloud platform such as Facebook, Google Drive and Dropbox. While you can manage your documents more effectively with features such as A3 printing, 2-sided print (up to A4), and easy scanning and copying.
The optional high-yield ink cartridges can also help lower your printing costs compared to standard yield ink. And rest assured the DCP-J4120DW complies with the strict ENERGY STAR, German Blue Angel and Nordic Swan environmental standards.
Change how you look at office printing. The DCP-J4120DW is a robust inkjet printer designed specifically to enhance productivity. Features such as automatic 2-sided print, connectivity to your mobile devices and A3 printing are all packed into its compact size, raising efficiency without losing valuable desk space.
Welcome to a new age of printing
Key Features
- Print up to A3, Copy & Scan up to A4
- Up to 20 mono / 18 colour ipm print speeds
- Automatic 2-sided printing
- 6.8cm colour touchscreen LCD
- Wireless ready + connect to your mobile device or the cloud
- Up to 1,200 page high-yield ink cartridges
ENHANCED CONNECTIVITY
With built-in wireless networking, the cloud connected DCPJ4120DW ensures seamless connections to your PC and mobile devices. Scan to and print directly from cloud services such as Dropbox, Evernote™ and Google Drive to digitise your paper-based content.
COST EFFECTIVE
High yield ink cartridges capable of up to 1,200 black and colour prints combined with other cost-saving features like 2-sided printing and ink save mode help to lower operating costs.
MOBILE INTEGRATION
Brother's mobile print and scan app provides seamless compatibility with Apple, Android and Windows devices. Print from or scan to your smartphone or tablet using the easy-to-use Brother iPrint&Scan app.
PROFESSIONAL
Ensure that your business is noticed by using the rear feed slot to print documents in A3 size. With a resolution of up to 6,000 x 1,200dpi, your prints will always look professional.
PRODUCTIVE
The DCP-J4120DW comes packed with a range of productivity solutions to help streamline your work, boasts fast print and scan speeds, and has an intuitive touch screen that's easy to navigate.
- Brother DCP-J4120DW - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Max Copying Speed
- Up to 12 ppm (mono) / up to 9 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 2400 dpi (mono) / up to 1200 x 2400 dpi (colour)
- Max Printing Speed
- Up to 35 ppm (mono) / up to 27 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 6000 dpi (mono) / up to 1200 x 6000 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 2.7"
- Original Size
- 215.9 x 297 mm (max)
- Original Type
- Sheets
- Media Size
- 89 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper, coated paper, glossy paper
- Standard Media Capacity
- 150 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to network, AOSS
- Power
- AC 230 V (50/60Hz)
- 48 cm x 29 cm x 16.3 cm
- 8.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Ink-jet - colour
- Display Diagonal Size
- 2.7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 128 MB
- Supported Flash Memory
- SD Memory Card, MultiMediaCard, Memory Stick Duo, USB flash drive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Nozzle Configuration
- 420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 1.5 pl
Scanning
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- 215.9 x 297 mm
- Original Type
- Sheets
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, 127 x 203 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 89 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 1 sheet
- 50 sheets
- Input tray - 150 sheets size: 89 x 127 mm - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , Output tray - 50 sheets
- Speed Details
- Printing: up to 20 ipm - B/W , Printing: up to 18 ipm - colour , Scanning: 3.37 sec (A4) - B/W , Scanning: 3.37 sec (A4) - colour , Copying: up to 12 ipm - B/W , Copying: up to 9 ipm - colour , Printing: up to 35 ppm - B/W fast , Printing: up to 27 ppm - colour fast
- 1 x USB 2.0 - 4 pin USB Type A , 1 x USB host - 4 pin USB Type A
- WEP, WPA-PSK, WPA2-PSK
- Operating System Support
- MS Windows XP Professional x64 Edition, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Windows 8.1, Windows 8.1 64-bit, Apple Mac OS X 10.7.5, MS Windows Server 2003 (32/64-bits), MS Windows Server 2003 R2 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, Apple Mac OS X 10.9.x, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits)
- Software Included
- Brother ControlCentre2, Brother MFL-Pro Suite, Brother ControlCenter4, Nuance PaperPort 12 SE
- Voltage Required
- 23 Watt
- Power Consumption Standby
- 5 Watt
- Power Consumption Sleep
- 1.3 Watt
- Direct Printing Specifications
- PictBridge
- Nordic Swan
- ENERGY STAR Certified
- Blue Angel Compliant
- 48 cm
- 29 cm
- 16.3 cm
- 8.1 kg
- Shipping Width
- 56.9 cm
- Shipping Depth
- 24.2 cm
- Shipping Height
- 39.8 cm
- Shipping Weight
- 10.1 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
