Fast, reliable and professional, the DCP-9015CDW brings all-in-one colour print, copy and scan performance to your office. Create shareable documents with impact, and share them using the machine’s comprehensive wireless and mobile and cloud connectivity options.
- Wireless and USB connectivity
- Full colour print, scan and copy
- 9.3cm touch screen
- 18ppm print speed
- 2-sided print
- Mobile and cloud compatible
The DCP-9015CDW offers a wide range of features designed with you and your business in mind, combined into a sleek, compact machine perfect for your office space. Embracing a range of new mobile features, print directly from your mobile device with the Brother iPrint&Scan app or use wireless print features such as AirPrint and Google Cloud Print. Print speeds of up to 18ppm mean you will not be kept waiting for your documents. Reduce your total print costs: the DCP-9015CDW offers high-yield colour toner cartridges, with yields of up to 2,200 pages for a lower cost per page, whilst maintaining high print quality for professional looking documents. All Brother Colour LED printers incorporate separate toners and drums reducing waste and saving you money. The DCP-9015CDW complies with the strict ENERGY STAR environmental standards and ensures low energy consumption, low noise levels and a recycle-friendly design
- Brother DCP-9015CDW - multifunction printer - colour
- Multifunction printer
- Printing Technology
- LED (colour)
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 600 x 2400 dpi (mono) / up to 600 x 2400 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 3.7"
- Original Size
- 215.9 x 300 mm (max)
- Original Type
- Sheets
- Media Size
- 76.2 x 116 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, AOSS, scan to FTP, scan to OCR
- Power
- AC 230 V (50/60Hz)
- 41 cm x 48.3 cm x 36.7 cm
- 21.9 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- LED - colour
- Display Diagonal Size
- 3.7"
- Display Features
- Touch screen
- Interface
- USB 2.0, Wi-Fi(n)
- AirPrint Enabled
- Standard Memory
- 192 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 16 sec
Scanning
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- 215.9 x 300 mm
- Original Type
- Sheets
- Min Media Size
- 76.2 x 116 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Output tray - 100 sheets , Bypass tray - 1 sheet size: 76.2 x 116 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Speed Details
- Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 7 ppm (A4) - B/W duplex , Printing: up to 7 ppm (A4) - colour duplex , Copying: up to 18 ppm - B/W , Copying: up to 18 ppm - colour
- 1 x USB 2.0 - 4 pin USB Type B
- Kerberos, SSL, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK, WPS, ARP, Wi-Fi Direct
- Operating System Support
- Linux, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits)
- Voltage Required
- 380 Watt
- Power Consumption Standby
- 70 Watt
- Power Consumption Sleep
- 8.5 Watt
- First Copy Out Time B/W
- 19 sec
- First Copy Out Time Colour
- 22 sec
- Consumables Included
- 1 x Cartridge (black) - up to 1000 pages , 1 x Cartridge (cyan) - up to 1000 pages , 1 x Cartridge (magenta) - up to 1000 pages , 1 x Cartridge (yellow) - up to 1000 pages
- Nordic Swan
- ENERGY STAR Certified
- Blue Angel Compliant
- 41 cm
- 48.3 cm
- 36.7 cm
- 21.9 kg
- Shipping Width
- 60.2 cm
- Shipping Depth
- 53.4 cm
- Shipping Height
- 56.5 cm
- Shipping Weight
- 27.7 kg
- Sound Emission
- 33 dBA (idle) / 53 dBA (operating)
- 10 °C
- 32.5 °C
- 20 - 80% (non-condensing)
