Brother DCP-9015CDW A4 Colour Multifunction Laser Printer
Quicklinx: CLMFWS00 Mfr#: DCP9015CDWZU1
Fast, reliable and professional, the DCP-9015CDW brings all-in-one colour print, copy and scan performance to your office. Create shareable documents with impact, and share them using the machine’s comprehensive wireless and mobile and cloud connectivity options.
  • Wireless and USB connectivity
  • Full colour print, scan and copy
  • 9.3cm touch screen
  • 18ppm print speed
  • 2-sided print
  • Mobile and cloud compatible
The DCP-9015CDW offers a wide range of features designed with you and your business in mind, combined into a sleek, compact machine perfect for your office space. Embracing a range of new mobile features, print directly from your mobile device with the Brother iPrint&Scan app or use wireless print features such as AirPrint and Google Cloud Print. Print speeds of up to 18ppm mean you will not be kept waiting for your documents. Reduce your total print costs: the DCP-9015CDW offers high-yield colour toner cartridges, with yields of up to 2,200 pages for a lower cost per page, whilst maintaining high print quality for professional looking documents. All Brother Colour LED printers incorporate separate toners and drums reducing waste and saving you money. The DCP-9015CDW complies with the strict ENERGY STAR environmental standards and ensures low energy consumption, low noise levels and a recycle-friendly design
Brother DCP-9015CDW - multifunction printer - colour
Multifunction printer
Printing Technology
LED (colour)
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 2400 dpi (mono) / up to 600 x 2400 dpi (colour)
Scanning
1200 x 2400 dpi
Display
3.7"
Original Size
215.9 x 300 mm (max)
Original Type
Sheets
Media Size
76.2 x 116 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, AOSS, scan to FTP, scan to OCR
AC 230 V (50/60Hz)
41 cm x 48.3 cm x 36.7 cm
21.9 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Printing Technology
LED - colour
Display Diagonal Size
3.7"
Display Features
Touch screen
USB 2.0, Wi-Fi(n)
AirPrint Enabled
Standard Memory
192 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3
Automatic Duplexing
First Print Out Time B/W
16 sec
First Print Out Time Colour
16 sec
Scanning
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Max Original Size
215.9 x 300 mm
Original Type
Sheets
Min Media Size
76.2 x 116 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
250 sheets
1 sheet
100 sheets
Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Output tray - 100 sheets , Bypass tray - 1 sheet size: 76.2 x 116 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Speed Details
Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 7 ppm (A4) - B/W duplex , Printing: up to 7 ppm (A4) - colour duplex , Copying: up to 18 ppm - B/W , Copying: up to 18 ppm - colour
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
Kerberos, SSL, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK, WPS, ARP, Wi-Fi Direct
Operating System Support
Linux, Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows XP (32/64 bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits)
AC 230 V (50/60Hz)
380 Watt
Power Consumption Standby
70 Watt
Power Consumption Sleep
8.5 Watt
First Copy Out Time B/W
19 sec
First Copy Out Time Colour
22 sec
Consumables Included
1 x Cartridge (black) - up to 1000 pages , 1 x Cartridge (cyan) - up to 1000 pages , 1 x Cartridge (magenta) - up to 1000 pages , 1 x Cartridge (yellow) - up to 1000 pages
Nordic Swan
ENERGY STAR Certified
Blue Angel Compliant
41 cm
48.3 cm
36.7 cm
21.9 kg
Shipping Width
60.2 cm
Shipping Depth
53.4 cm
Shipping Height
56.5 cm
Shipping Weight
27.7 kg
Sound Emission
33 dBA (idle) / 53 dBA (operating)
10 °C
32.5 °C
20 - 80% (non-condensing)
