Brother DCP-1610W Mono Laser Multifunction Printer
Quicklinx: 9X76WS00 Mfr#: DCP1610WZU1
Type: Printer / copier / scanner
Functionality: Scanner, Copier, Printer
Output Type: Monochrome
Wireless Capability: Wireless, Wired
Technology: Laser
£128.96 ex VAT
£154.75 inc VAT
The Brother DCP-1610W is stylishly designed and compact enough to fit onto a shelf or workstation. It produces outputs with the speed and quality you would expect from a more expensive machine.
Installation is very easy – connect using wireless or the USB cable, and you will be printing in no time. Plus innovative Anti-Jam technology allows you to print wirelessly with no hassle. You will also be able to print at speeds of up to 20 pages per minute (ppm), and your first page will come out in less than 10 seconds.
  • Connectivity brings convenience
    Enjoy convenience, flexibility and easy connectivity to multiple devices with smart built-in features such as Mobile Printing that simply boost productivity.
  • High productivity, less fuss
    Eliminate excessive downtime with Brother networking administration tools which provides status monitoring and configuration capabilities.
  • Improve productivity and save time
    Featuring print speeds up to 20 ppm, higher print speeds save time for multiple users and on large volume printing tasks. Users can utilize their time more efficiently instead of waiting for their printouts.
Brother DCP-1610W - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 2400 x 600 dpi
Scanning
600 x 1200 dpi
Original Size
215.9 x 300 mm (max)
Original Type
Sheets
Media Size
148 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper
Standard Media Capacity
150 sheets
Output Trays Capacity
50 sheets
Connection Availability
USB 2.0, Wi-Fi(n)
Office Machine Features
AOSS
AC 230 V (50/60Hz)
38.5 cm x 34 cm x 25.5 cm
7.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Laser - monochrome
Display
2 lines x 16 characters
USB 2.0, Wi-Fi(n)
AOSS
Standard Memory
32 MB
Copying
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Up to 20 ppm
Printer Drivers / Emulations
Windows GDI driver
Image Enhancement Technology
Brother HQ1200
First Print Out Time B/W
10 sec
Scanning
Scan Element
CIS
Optical Resolution
600 x 1200 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
215.9 x 300 mm
Original Type
Sheets
Min Media Size
148 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
65 g/m²
Max Media Weight
105 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm), 148 x 148 mm
150 sheets
50 sheets
Input tray - 150 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 65 g/m² - 105 g/m² , Output tray - 50 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W , Printing: up to 21 ppm (Letter A) - B/W
1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK, TKIP, AES, ARP
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, Android, iOS, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Server 2012 R2 x64 Edition, Apple Mac OS X 10.10
AC 230 V (50/60Hz)
390 Watt
Power Consumption Standby
1.5 Watt
Power Consumption Sleep
0.9 Watt
First Copy Out Time B/W
16 sec
Consumables Included
1 x toner cartridge (black) - up to 700 pages , 1 x drum - up to 10000 pages - Brother DR1050
IEC 60825-1:2007
ENERGY STAR Certified
38.5 cm
34 cm
25.5 cm
7.2 kg
Shipping Width
48.1 cm
Shipping Depth
43.6 cm
Shipping Height
40.6 cm
Shipping Weight
9 kg
Sound Emission
32 dBA (idle) / 52 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
9X76 Brother Drum Unit 10K In Stock £44.98
Functionality: Copier
Functionality: Printer
Wireless Capability: Wired
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Brother
