Genuine Brother laser toner cartridges are designed specifically to work with the system design. Each component of a Brother laser product is designed to work with the other.
All Brother original supplies are manufactured to the highest possible standards in controlled clean rooms. Each cartridge is rigorously print tested in order that every user can be assured of the quality and performance they expect.
- Brother TN130BK - black - original - toner cartridge
- Product Type
- Toner cartridge
- Printing Technology
- Laser
- Printing Colour
- Black
- Yield
- Up to 2500 pages at 5% coverage
- Compatible with
- Brother DCP-9040CN, DCP-9042CDN, DCP-9045CDN, HL-4040CN, HL-4050CDN, HL-4070CDW, MFC-9440CN, MFC-9450CDN, MFC-9840CDW
- Dimensions (WxDxH) / Weight
- 30.99 cm x 5.95 cm x 11.26 cm / 662 g
- Shipping Width
- 36.5 cm
- Shipping Depth
- 15 cm
- Shipping Height
- 19.5 cm
- Shipping Weight
- 1.293 kg
Consumable
- Consumable Type
- Toner cartridge
- Laser
- Black
- Included Qty
- 1-pack
- Yield
- Compatible with
