Brother ADS-3600W Touch Screen Desktop Office Scanner
Quicklinx: C57MWS00 Mfr#: ADS3600WZU1
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 215.9 x 5000 mm
Interface: Gigabit LAN, USB 2.0 (Host), USB 3.0, Wi-Fi(n)
Compatibility: Mac, PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
Hurry, only 3 left in stock!
£509.85 ex VAT
£611.82 inc VAT
This affordable and space-saving network 600dpi scanner boasts great scan speeds, user-friendly software, easily programmable keys and compatibility across a range of document types, drivers and operating systems. The robust ADS-2400N is capable of scanning up to 3,000 sheets per day, making it ideal for continued office departmental scanning and reliable hard copy digitisation.
Brother ADS-3600W - document scanner - desktop - USB 3.0, Gigabit LAN, Wi-Fi(n), USB 2.0 (Host)
Document scanner - desktop
Interface Type
Additional Functions
Email, scan to print, scan to cloud, scan to USB, scan to FTP
Max Supported Document Size
215.9 x 5000 mm
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 30-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
50 ppm (mono) / 50 ppm (colour)
Max Document Size
215.9 mm x 5000 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
5000 scans per day
Microsoft Windows Server 2003, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Apple MacOS X 10.8, Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Apple MacOS X 10.11
30.6 cm x 25.8 cm x 25 cm
4.55 kg
Interface Type
215.9 x 5000 mm
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
30-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Max Document Scan Speed B/W
50 ppm
Max Document Scan Speed Colour
50 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
50 ppm - black & white - A4 , 50 ppm - colour - A4 , 100 ipm - duplex - black & white - A4 , 100 ipm - duplex - colour - A4
Scanner Features
Scan to portable USB drive, 3.7" touch screen LCD display
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215.9 mm x 5000 mm
Plain paper
Supported Document Size Details
ADF
Automatic
50 sheets
USB 2.0 (Host) - Type A , Gigabit LAN , USB 3.0 - Type B
1 x SuperSpeed USB cable
Internal power supply
Power Consumption Operational (Standby)
30 Watt
Power Consumption Stand by
4.9 Watt
Power Consumption Sleep
2.9 Watt
Software Included
Brother Control Center 4, Brother Control Center 2, Nuance PaperPort 14, ABBYY FineReader Sprint 12
30.6 cm
25.8 cm
25 cm
4.55 kg
5 °C
35 °C
20 - 80%
Interface: USB 2.0 (Host)
Interface: USB 3.0
Interface: Wi-Fi(n)
Compatibility: Mac
Compatibility: PC
Brand: Brother
Price Range Ex VAT: 500 - 750
