Brother ADS-2800W Touch Screen Desktop Office Scanner
Quicklinx: C57LWS00 Mfr#: ADS2800WZU1
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
£350.08 ex VAT
£420.09 inc VAT
This affordable and space-saving network 600dpi scanner boasts great scan speeds, user-friendly software, easily programmable keys and compatibility across a range of document types, drivers and operating systems. The robust ADS-2400N is capable of scanning up to 3,000 sheets per day, making it ideal for continued office departmental scanning and reliable hard copy digitisation.
  • Network Scanners
    Offering true network capability with no need to install software at multiple location points, Brother Network scanners allow documents to be scanned directly from the machine to multiple devices. With one simple press of a button or Touchscreen, scans can be quickly and easily shared across teams and departments; improving workflow efficiency and increasing productivity.
  • Brother Solutions Interface (BSI)
    BSI is a software interface that enables third-party developers to build custom solutions for, or to integrate with, Brother devices. Customised menus and screens can be created to provide great capabilities - helping customers improve operations as well as reducing costs, wastage and risk.
  • Secure Function Lock (SFL)
    SFL is a security function which can disable or enable configuration settings and allow user restrictions to be put in place. It also has a public mode which allows functions to be left unrestricted. SFL allows administrators to restrict scanner settings per user, allowing for function management and improved security.
  • Scan to USB Host
    The scan to USB Host feature allows the connection of an external storage flash drive up to 64 GB.
  • Professional Paper Handling
    Powerful, professional scanners, but still desktop friendly, Brother scanners can handle a range of media weights, using a wider output tray to neatly capture paper fed through the Automatic Document Feeder (ADF).
  • Multifeed Detection
    This system uses sound waves to identify potential misfeeds. The paper pathway is automatically suspended and the user alerted if an irregular signal is detected, reducing the risk of damaged documents and lost data.
  • Advanced Reverse Roller System
    This advanced system manages incoming bulk paper jobs so only one sheet is processed at a time, for outstanding reliability when scanning a variety of document types and weights.
  • Advanced Image Processing Features
    The built-in range of powerful scanning tools intuitively prepare and clean scanned files, improving the quality of the scanned image for storing, editing, sharing and OCR (Optical Character Recognition) needs.
Brother ADS-2800W - document scanner - desktop - USB 2.0, Gigabit LAN, Wi-Fi(n), USB 2.0 (Host)
Document scanner - desktop
Interface Type
Additional Functions
Email, scan to print, scan to cloud, scan to USB, scan to FTP
Max Supported Document Size
215.9 x 5000 mm
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 30-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
30 ppm (mono) / 30 ppm (colour)
Max Document Size
215.9 mm x 5000 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3000 scans per day
Microsoft Windows Server 2003, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Microsoft Windows Server 2012 R2 x64 Edition, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
30.6 cm x 25.8 cm x 25 cm
4.55 kg
Interface Type
215.9 x 5000 mm
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
30-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Max Document Scan Speed B/W
30 ppm
Max Document Scan Speed Colour
30 ppm
Duty Cycle
3000 scans per day
Scanner Speed Details
30 ppm - black & white - A4 , 30 ppm - colour - A4 , 60 ipm - duplex - black & white - A4 , 60 ipm - duplex - colour - A4
Scanner Features
Scan to portable USB drive, 3.7" touch screen LCD display
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215.9 mm x 5000 mm
Plain paper
Supported Document Size Details
ADF
Automatic
50 sheets
Interfaces Details
USB 2.0 (Host) - Type A , Gigabit LAN , USB 2.0 - Type B
1 x USB cable
Internal power supply
Power Consumption Operational (Standby)
27 Watt
Power Consumption Stand by
3.7 Watt
Power Consumption Sleep
1.9 Watt
Software Included
Brother Control Center 4, Brother Control Center 2, Nuance PaperPort 14, ABBYY FineReader Sprint 12
30.6 cm
25.8 cm
25 cm
4.55 kg
5 °C
35 °C
20 - 80%
