Reduce time spent on repetitive scan tasks with the ADS-2600We. The 9.3cm colour touchscreen allows users to quickly access features from the advanced 48 programmable shortcuts on the LCD swipe home screen. The ADS-2600We also incorporates Secure Function Lock and Active Directory Authentication, controlling usage and providing a secure scan environment.
Supported by 2-sided scan speeds of up to 24 pages per minute (48ipm) with a 50 sheet Automatic Document Feeder (ADF), the ADS-2600We offers network connectivity enabling multiple staff to share documents via the wired or wireless connection. Bundled with a range of software for document management and OCR.
- Brother ADS-2600We - document scanner - desktop - USB 2.0, LAN, Wi-Fi(n), USB 2.0 (Host)
- Document scanner - desktop
- Interface Type
- Max Supported Document Size
- 216 x 863 mm
- Input Type
- Grayscale / Color Depth
- 8-bit (256 colours) / 30-bit colour
- Grayscale / Color Depth (External)
- 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 24 ppm (mono) / 24 ppm (colour)
- Max Document Size
- 216 mm x 863 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Linux, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple MacOS X 10.8.x, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x, Apple MacOS X 10.10.x
- 29.9 cm x 22 cm x 17.9 cm
- 3.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- 216 x 863 mm
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 30-bit colour
- Colour Depth (External)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Max Document Scan Speed B/W
- 24 ppm
- Max Document Scan Speed Colour
- 24 ppm
- Scanner Speed Details
- 24 ppm - black & white - A4 , 24 ppm - colour - A4
- Scanner Features
- Scan to portable USB drive, 3.7" touch screen LCD display
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 863 mm
- Plain paper
- Supported Document Size Details
- ADF - up to 216 x 863 mm
- Automatic
- 50 sheets
- USB 2.0 - Type B , LAN , USB 2.0 - Type A
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Voltage Required
- Power Consumption Operational (Standby)
- 20 Watt
- Power Consumption Stand by
- 4 Watt
- Power Consumption Sleep
- 2 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 29.9 cm
- 22 cm
- 17.9 cm
- 3.6 kg
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 49 dBA
