Brother ADS-2600WE A4 Document Scanner
Quicklinx: BJ70WS00 Mfr#: ADS2600WEZU1
Reduce time spent on repetitive scan tasks with the ADS-2600We. The 9.3cm colour touchscreen allows users to quickly access features from the advanced 48 programmable shortcuts on the LCD swipe home screen. The ADS-2600We also incorporates Secure Function Lock and Active Directory Authentication, controlling usage and providing a secure scan environment.
Supported by 2-sided scan speeds of up to 24 pages per minute (48ipm) with a 50 sheet Automatic Document Feeder (ADF), the ADS-2600We offers network connectivity enabling multiple staff to share documents via the wired or wireless connection. Bundled with a range of software for document management and OCR.
Brother ADS-2600We - document scanner - desktop - USB 2.0, LAN, Wi-Fi(n), USB 2.0 (Host)
Document scanner - desktop
Interface Type
Max Supported Document Size
216 x 863 mm
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 30-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
24 ppm (mono) / 24 ppm (colour)
Max Document Size
216 mm x 863 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Linux, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple MacOS X 10.8.x, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x, Apple MacOS X 10.10.x
29.9 cm x 22 cm x 17.9 cm
3.6 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
216 x 863 mm
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
30-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Scan Mode
Single-pass
Automatic Duplexing
Max Document Scan Speed B/W
24 ppm
Max Document Scan Speed Colour
24 ppm
Scanner Speed Details
24 ppm - black & white - A4 , 24 ppm - colour - A4
Scanner Features
Scan to portable USB drive, 3.7" touch screen LCD display
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 863 mm
Plain paper
Supported Document Size Details
ADF - up to 216 x 863 mm
Automatic
50 sheets
USB 2.0 - Type B , LAN , USB 2.0 - Type A
1 x USB cable
ENERGY STAR Certified
Power Consumption Operational (Standby)
20 Watt
Power Consumption Stand by
4 Watt
Power Consumption Sleep
2 Watt
Software Included
Drivers & Utilities
29.9 cm
22 cm
17.9 cm
3.6 kg
5 °C
35 °C
20 - 80%
Sound Emission
49 dBA
