Brother ADS-2400N A4 Colour Document Scanner
Quicklinx: CQ23WS00 Mfr#: ADS2400NZU1
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 215.9 x 5000 mm
Interface: Gigabit LAN, USB 2.0, USB 2.0 (Host)
Compatibility: Mac, PC
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
More than 50 in stock
£249.90 ex VAT
£299.88 inc VAT
The ImageCenter ADS-2400N desktop scanner with Gigabit Ethernet networking offers powerful features for mid-to-large size workgroups that help simplify the way documents are captured, managed, processed, and delivered. The ImageCenter ADS-2400N boasts various integrated image optimization features, including multi-feed detection, background removal, blank page removal and deskew support, and many more.
  • Fast, durable desktop document scanner with networking - designed with workgroups in mind
    The Brother ImageCenter ADS-2400N desktop scanner is a reliable addition to your mid-to-large size workgroup which will help simplify the way documents are captured, managed, processed, and delivered. Ideally suited for a wide variety of office environments, the ADS-2400N offers wired Gigabit Ethernet network connectivity as well as a Hi-Speed USB 2.0 interface for local connections.
  • Scan to a variety of local or shared destinations
    The ADS-2400N gives you the option to easily scan to a number of different destinations to help you manage your documents and workflow, including scanning to a file, an image, OCR software, or even to a printer.
  • Advanced document capture solutions designed for businesses
    With flexible media handling capabilities, the ADS-2400N can digitize materials. It also includes a variety of integrated image optimization features to help maximize output quality, including hole punch removal, edge cleanup, despeckle, background removal and more. Advanced scanning features further enhance capture versatility, including 2-in-1 mode for capturing 11" x 17" documents, and Continuous Scan Mode for scanning unlimited pages into a single file.
Brother ADS-2400N - document scanner - desktop - USB 2.0, Gigabit LAN, USB 2.0 (Host)
Document scanner - desktop
Interface Type
Additional Functions
Email, scan to cloud, scan to USB
Max Supported Document Size
215.9 x 5000 mm
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 30-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
30 ppm (mono) / 30 ppm (colour)
Max Document Size
215.9 mm x 5000 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
3000 scans per day
Microsoft Windows Server 2003, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Apple MacOS X 10.8, Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Apple MacOS X 10.11
30.6 cm x 25.8 cm x 25 cm
4.45 kg
Interface Type
215.9 x 5000 mm
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
30-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Max Document Scan Speed B/W
30 ppm
Max Document Scan Speed Colour
30 ppm
Duty Cycle
3000 scans per day
Scanner Speed Details
30 ppm - black & white - A4 , 30 ppm - colour - A4 , 60 ipm - duplex - black & white - A4 , 60 ipm - duplex - colour - A4
Scanner Features
Scan to portable USB drive
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215.9 mm x 5000 mm
Plain paper
Supported Document Size Details
ADF
Automatic
50 sheets
USB 2.0 (Host) - Type A , Gigabit LAN , USB 2.0 - Type B
1 x USB cable
Internal power supply
Power Consumption Operational (Standby)
27 Watt
Power Consumption Stand by
3 Watt
Power Consumption Sleep
1.9 Watt
Software Included
Brother Control Center 4, Brother Control Center 2, Nuance PaperPort 14, ABBYY FineReader Sprint 12
30.6 cm
25.8 cm
25 cm
4.45 kg
5 °C
35 °C
20 - 80%
Interface: USB 2.0
Interface: USB 2.0 (Host)
Compatibility: Mac
Compatibility: PC
Brand: Brother
Price Range Ex VAT: 150 - 300
