Brother ADS-1600W
Brother ADS-1600W
Quicklinx: 95Y4WS00 Mfr#: ADS1600WZU1
  • Windows 8 (32/64 bits)
Mobile devices are now vital when it comes to how we all do business, so a scanner that's fully up to speed with the way you work right now is a real asset.
The ADS-1600W has wireless network connectivity built in and makes scanning, organising and sharing information direct to your mobile device or the cloud quick and simple. It will perform fast double-sided scanning in a single pass up to 1,200 dpi, as well as easily tackling larger documents thanks to the automatic document feeder. And the included professional software bundle makes all kinds of document management and manipulation simple.
So from the easy-to-use 6.8cm colour touch screen to the 18ppm scan speed, the ADS-1600W is all set up to meet your modern office needs.
Brother ImageCenter ADS-1600W - document scanner - desktop - USB 2.0, Wi-Fi(n)
Document scanner - desktop
Interface Type
USB 2.0, Wi-Fi(n)
Scanning Sensor Type
Dual CIS
Additional Functions
Email, scan to network share, scan to server
Max Supported Document Size
215.9 x 863 mm
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 30-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
18 ppm (mono) / 18 ppm (colour)
Max Document Size
215.9 mm x 863 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card, photo
Document Feeder Type
Automatic
Document Storage Capacity
20 sheets
Duty Cycle
500 scans per day
AC 230V (50/60 Hz)
Linux, Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Windows 8 (32/64 bits), Apple MacOS X 10.8.x
Microsoft Certification
Compatible with Windows 7
28.5 cm x 10.3 cm x 8.4 cm
1.6 kg
Interface Type
USB 2.0, Wi-Fi(n)
215.9 x 863 mm
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
30-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Scan Mode
Single-pass
Automatic Duplexing
Dual CIS
Max Document Scan Speed B/W
18 ppm
Max Document Scan Speed Colour
18 ppm
Duty Cycle
500 scans per day
Scanner Speed Details
18 ppm - black & white - A4 - 300 dpi , 18 ppm - colour - A4 - 300 dpi , 18 ppm - duplex - black & white - A4 - 300 dpi , 18 ppm - duplex - colour - A4 - 300 dpi
Scanner Features
Scan to portable USB drive, AirStation One-Touch Secure System (AOSS), 2.7" touch screen LCD display
TWAIN, ISIS, WIA
Media Handling
Max Document Size
215.9 mm x 863 mm
Supported Document Size Details
ADF - up to 215.9 x 863 mm
Automatic
20 sheets
USB 2.0 - Type B , USB - Type A
1 x USB cable
Internal power supply
AC 230V (50/60 Hz)
Power Consumption Operational (Standby)
14 Watt (1.5 Watt)
Software Included
Drivers & Utilities
28.5 cm
10.3 cm
8.4 cm
1.6 kg
5 °C
35 °C
20 - 80%
Sound Emission
59 dB
