Brother A4 DT Workgroup Document Scanner 35ppm Colour 600 dpi 1 Year
Quicklinx: DZB3WS00 Mfr#: ADS2200ZU1
Type: Document scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: USB 2.0, USB 2.0 (Host)
Hurry, only 3 left in stock!
£193.18 ex VAT
£231.81 inc VAT
The easy to use ADS-2200 desktop scanner is ideal for business scanning needs with fast double sided scan speeds, Windows and Mac compatibility and much more...
  • Scan to a variety of file types and optimize
    Users can scan to searchable PDF, file, email, OCR, image and directly to USB flash drives while image processing features such as auto-deskew and hole punch removal ensure that digital backups of hard copies are more than just images - they become optimized, business-ready documents.
  • Small on size, big on efficiency
    When the output tray is conveniently folded back into the unit's body, this space-saving desktop scanner takes up similar width and depth dimensions to that of a single piece of A4 paper. While compact in size, this 35ppm scanner is robust and reliable enough for daily business use.
  • Easily integrated with your existing systems
    The Brother ADS-2200 is easily connected to a desktop or laptop running Windows, MacOS or Linux via Hi-Speed USB 2.0 and is easy to operate with minimal user intervention.
  • 50 sheet mixed media automatic document feeder
    Its ability to process mixed media types within the same feed allows users to quickly back up a variety of business critical documents quickly and efficiently in one pass.
Brother ADS-2200 - document scanner - desktop - USB 2.0, USB 2.0 (Host)
Document scanner - desktop
Interface Type
Additional Functions
Scan to USB, scan to file, scan to email, scan to OCR
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 48-bit colour
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
35 ppm (mono) / 35 ppm (colour)
Max Document Size
216 mm x 5000 mm
Automatic Duplexing
Supported Document Type
Plain paper, photo
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
29.9 cm x 14.5 cm x 14.1 cm
2.6 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
A4 (210 x 297 mm)
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
48-bit colour
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Scan Mode
Single-pass
Automatic Duplexing
Max Document Scan Speed B/W
35 ppm
Max Document Scan Speed Colour
35 ppm
Scanner Speed Details
35 ppm - black & white , 35 ppm - colour , 70 ipm - duplex - black & white , 70 ipm - duplex - colour
TWAIN, WIA, SANE, ICA
Media Handling
Max Document Size
216 mm x 5000 mm
Plain paper, photo
Automatic
50 sheets
USB 2.0 , USB 2.0 (Host)
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
21 Watt
Power Consumption Stand by
4.7 Watt
Power Consumption Sleep
0.8 Watt
29.9 cm
14.5 cm
14.1 cm
2.6 kg
Limited warranty - 1 year
5 °C
35 °C
Interface: USB 2.0
Interface: USB 2.0 (Host)
Brand: Brother
Price Range Ex VAT: 150 - 300
