Brocade optical transceiver modules connect Brocade switches, directors, backbones, HBAs, and CNAs to a broad spectrum of data center resources, providing Fibre Channel and Ethernet connectivity, and satisfying a wide range of speed and distance requirements.
- Ruckus - SFP (mini-GBIC) transceiver module - GigE
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX
- Data Transfer Rate
- 1 Gbps
- Data Link Protocol
- GigE
- Max Transfer Distance
- 550 m
- Designed For
- Brocade BigIron RX-16, 32, RX-4, RX-8; FastIron GS 624, 648; FastIron LS FLS624, FLS648; FastIron SuperX SX800; FastIron SX 1600, 800; ICX 6430, 6450, 6610, 6650, 7750; ServerIron ADX 1000, 10000, 4000, 8000; TurboIron 24; VDX 6710, 6720, 6730, 6740
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-SX
- GigE
- 1 Gbps
- 550 m
- Digital Optical Monitoring (DOM) support
- 1 x Ethernet 1000Base-SX - LC multi-mode female x 2
- Compatible Slots
- 1 x SFP (mini-GBIC)
- Designed For
- Brocade BigIron RX-16, RX-32 AC system, RX-32 DC system, RX-4, RX-8 , Brocade FastIron GS 624P, 624P-DC-EPREM, 624P-DC-STK, 624P-EPREM, 624P-POE, 624P-POE-DC-EPREM, 624P-POE-DC-STK, 624P-POE-EPREM, 624P-POE-STK, 624P-STK, 624P-STK-CXU, 648P, 648P-DC-EPREM, 648P-DC-STK, 648P-EPREM, 648P-POE, 648P-POE-DC-EPREM, 648P-POE-DC-STK, 648P-POE-EPREM, 648P-POE-STK, 648P-STK , Brocade FastIron LS FLS624, FLS624-STK, FLS648, FLS648-EPREM, FLS648-STK , Brocade FastIron SuperX SX800-DC , Brocade FastIron SX 1600, 800 , Brocade ICX 6430-24, 6430-24P, 6430-48, 6430-48P, 6430-C12, 6450-24, 6450-24P, 6450-48, 6450-48P, 6450-C12-PD, 6610-24, 6610-24F, 6610-24P, 6610-48, 6610-48P, 6650-32, 6650-40, 6650-48, 6650-56, 6650-80, 7750-26Q, 7750-48C, 7750-48F , Brocade ServerIron ADX 1000, 10000, 1000-DC, 1000F, 1000-PREM, 1000-SSL, 1000-SSL-PREM, 4000, 8000 , Brocade TurboIron 24x , Brocade VDX 6710, 6720, 6730, 6740, 6740T, 6740T-1G
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.07 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.55 |
C2G 2m Cat6a Shielded Patch - Blue | In Stock | £6.44 |
C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue | In Stock | £40.80 |
