Your basket is empty
Brocade SFP & Transceiver Module - 10GBase-USR
Quicklinx: 9P3FWS00 Mfr#: 10G-SFPP-USR
Type: Modules
£424.58 ex VAT
£509.49 inc VAT
Brocade offers a unique set of high performance, reliable, and cost-effective optical transceiver that help enterprises and service providers meet the challenges of diverse network topologies. To ensure maximum quality, Brocade selects and tests the most reliable, high-performing optical transceivers on the market, and then warrants their availability, capacity, and performance in Brocade products.
Extensive performance and reliability testing reflects an ongoing commitment to quality. Brocade tests transceivers using the industry's advanced tools and instruments to help ensure that they provide the right mix of functionality and performance when used in conjunction with Brocade product. The speed, capacity, reliability, and low cost of ownership that Brocade is known for is also provided in all optical components.
Brocade - SFP+ transceiver module - 10 Gigabit Ethernet
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-USR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10 Gigabit Ethernet
Max Transfer Distance
100 m
1.5 cm x 5.7 cm x 1.2 cm
ICX 6430-24, 6430-24P, 6430-48, 6430-48P, 6430-C12, 6450-24, 6450-24P, 6450-48, 6450-48P, 6450-C12-PD, 7750-26Q, 7750-48C, 7750-48F
Plug-in module
Wired
Cabling Type
10GBase-USR
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
100 m
Hot swap module replacement, full duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
1 x Ethernet 10GBase-USR - LC multi-mode
Compatible Slots
1 x SFP+
UL 60950, CSA 22.2 No. 60950, RoHS, EN 60825, IEC 60825-1
1 Watt
1.5 cm
5.7 cm
1.2 cm
Brocade ICX 6430-24, 6430-24P, 6430-48, 6430-48P, 6430-C12, 6450-24, 6450-24P, 6450-48, 6450-48P, 6450-C12-PD, 7750-26Q, 7750-48C, 7750-48F
Type: Modules
Brand: Brocade
Price Range Ex VAT: 300 - 500
