Product
Bretford PureCharge Cart 40
Quicklinx: B7K8WS00 Mfr#: HGFM2ZM/A
The ready-to-go iPad charging solution. No cables or power adapters required. The PureCharge Cart 40, Cart 20, Station 20 and Station 10 are the first family of charge-only solutions that are ready to go without the need to add cables or power adapters included with your devices.
With the convenience of pre-installed Lightning cables and no setup required, the PureCharge products saves valuable time and money while freeing up cables and power adapters for use elsewhere in your deployment.
  • Simultaneous charge
    Provides simultaneous charging for up to 40 devices.
  • Ready to go
    With pre-installed Lightning cables, simply plug in the cart and it's ready to go, right out of the box.
  • Optimized cables
    Cable clutter is eliminated through custom cables that are the optimal length for each slot and the right-angled Lightning connector makes it easy to connect devices.
  • At-a-glance status
    Without removing them from the slot, instantly determine which devices are fully charged via the individual charge status LEDs.
  • Scalable
    The PureCharge family of products is designed to grow with your organization. Stations can be stacked and the Cart 20 is upgradeable to 40 device slots.
Bretford PureCharge Cart 40 HGFM2 - cart
Cart
92.2 cm x 55.4 cm x 97 cm
69.3 kg
Recommended Use
40 tablets
Outlets Qty
40
Material
Steel
Platinum powder
12 years warranty
Apple iPad Air; iPad mini; iPad mini 2; iPad with Retina display (4th generation)
92.2 cm
55.4 cm
97 cm
69.3 kg
Material
Steel
Platinum powder
AV Furniture
Cart
Recommended Use
40 tablets
Output
2.1 A
Outlets Qty
40
Limited warranty - 12 years , Limited warranty - electrical components - 3 years
Apple iPad Air , Apple iPad mini , Apple iPad mini 2 , Apple iPad with Retina display (4th generation)
